E30 (1982 - 1993)
Old 09-23-2009, 02:05 PM
teddygraham teddygraham is offline
hopeless
Mein Auto: 1984 bmw 325e
Question please help me someone if you find the problem i will pay you!
ok so i have a 1984b mw 325e. so i first got it it only drove a little bit then smogged down it wasny getting enough fuel but in first drove fine, so i replaced the fuel pump which was bad ran a little bit better like it didnt want to die as bad and lasted a little longer so then i looed around and there was rust in the tank, which was clogging the filter so i replaced that with a new tank and cleaned the fuel filter. wheni went to try to start it the first like 10 times it didnt start so then i finallyl got it to and it reved up then when right back down. i know its getting fuel all the way to the filter in the tank and i know the filter is good what ellse could it be? it never will even stay at idle, when before it could stay in nuetral and you could rev it up and still wouldnt die and stayed at idle. please please please help me im bout to get rid of this dream car that i always wanted
Old 09-23-2009, 03:36 PM
downhiller's Avatar
livin large
which fuel pump did you replace? did you change the fuel filter (cleaning this is not a good idea)? vacuum leaks will cause this as well, and did you check the fuel pressure regulator? and the last piece of advice, check the air flow meter. could be goin out.
now whats this pay if i find? how much we talkin
Old 09-23-2009, 04:13 PM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
is your air filter dirty?
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 09-23-2009, 04:29 PM
claver claver is offline
Mein Auto: 1997 328i
hold on men, this is the same post again, only this time ure including the money. Did u finished checking out everything i told u?
Old 09-23-2009, 04:49 PM
downhiller's Avatar
livin large
he like posted it 3 times
Old 09-23-2009, 05:51 PM
last2letUdwn last2letUdwn is offline
Mein Auto: 1991 BMW 325ic convertibl
Junk in the fuel tank or maybe bad fuel
