Old 09-24-2009, 10:03 AM
JR Florida JR Florida is offline
Mein Auto: 2006 750 Li
Question 2006 750 Li - Low Oil warning between scheduled changes
I recently had to add 2 quarts of oil because the low oil warning came on. It actually read "Oil level at minimum level" and it alerted me each time the car was shut off. I took it into the dealer and they topped it off.
Here are the questions:
Why does the car need oil?
Is this normal?
Does the need for more oil indicate a leak somewhere? I am not noticing anything on my garage floor.
If there is no leak, why would it be burning oil?
Thanks.
Old 09-24-2009, 11:12 AM
kjruben kjruben is offline
Mein Auto: BMW 760Li V12
My 760 does the same thing and when I asked the SA at the dealer he stated it was normal.
Old 09-24-2009, 11:58 AM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
i would say that its usual for a 760 to eat that much oil but not for a 750
'08 BMW 535i - Sport - Sport Trans - JB4 - Catless DPs - Intake - E85 -
'07 SUZUKI GSXR-750 - Gray/Black - Akrapovic Titanium Exhaust -
'03 BMW 525i - Sport -
'98 Ford Expedition - 5.4L - 4WD - Eddie Bauer - 8 seater -
'03 BMW 745i - GONE -
'09 HONDA CBR600RR - GONE -
Old 09-24-2009, 02:09 PM
bembo19 bembo19 is offline
Mein Auto: E65 745
i know that some cars burn oil if its of the wrong grade or quality ! shouldn't be from a dealer though !
Old 09-24-2009, 02:17 PM
Joe-BMW's Avatar
Joe-BMW Joe-BMW is offline
Mein Auto: F10, E39, Audi Q7
I get the same thing sometimes between oil changes. There's not leak, my SA said it is normal as well. They burn a little.
2012 535xi|Dark Graphite|Black Interior|M-Sport|
Prior BMW's: 1987 325e|1993 740i|1998 740il|2002 745li|2007 750li|2006 750li
Old 09-24-2009, 02:19 PM
Mein Auto: E65 745
750 is a V12 right ??
Old 09-24-2009, 05:43 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
no, 760 has the 6L V12, 750 has the 4.8L V8
Old 09-24-2009, 06:02 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Is this normal?
Thanks.
How long are you going between oil changes? All cars burn a small amount of oil, as some is left on the cylinder walls when the pistons slide up and down. Some cars more than others. If your going say 8 thousand miles between oil changes, its normal to burn a couple quarts. Again, some motors will burn more and some less because there are many variables including your driving style, the weather conditions in your area, and the type of oil you use.
Old 09-24-2009, 08:44 PM
Mein Auto: E65 745
check it more often ! will give you an idea of how much your using !!??
Old 09-26-2009, 05:13 AM
bbford bbford is offline
Mein Auto: 2002 BMW 745LI
My 05 did that. I'd add about a half a quart or so, and it would go off. I thought there is no way to check the oil. I know it takes 8 quarts. Never added 2 quarts, but it has happened to me. Summed it up to being normal. When I called BMW, they seemed it was no big deal. Added oil and kept going.
2006, 750, leak, oil
