Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 09-25-2009, 02:39 PM
mlbryant8 mlbryant8 is offline
Mein Auto: 1992 white cabrio mtech
1989 cabrio
New member. Hello to everyone. Want to put bigger tires on my e30. It currently has 14 inch rims. Have seen some 16 inch stock rims from newer 3 series online. Does anyone know if all 3 series stock rims will fit or is there more info needed to determine a fit?
Old 09-25-2009, 02:51 PM
claver claver is offline
Mein Auto: 1986 325 es
just make sure that is not the ix model, as it is different 3 series since its a 4 wd model.
Old 09-25-2009, 04:12 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
i think the OP was meaning newer as in E36/46 etc, but i may be wrong. wheels off those cars wont fit because they are the wrong pattern. you need 4x100 and an offset of around 20
Old 09-26-2009, 01:12 PM
good point, i was only making sure he doesnt make the common mistake between the ix and every other model. but aren e36/46 5 bolts??
Old 09-26-2009, 01:25 PM
yeah they are, thats why i said they have the wrong stud pattern
Old 09-26-2009, 09:00 PM
Are you saying that the stock bmw 5 bolt patterns vary such that all 3 series stock rims are not interchangable. I seem to recall reading somewhere that the bolt pattern stayed the same up to 2001.
Old 09-26-2009, 09:06 PM
jleon426 jleon426 is offline
e30 project
Send a message via MSN to jleon426 Send a message via Yahoo to jleon426
Mein Auto: lokking for an e30
no all e30s have a 4x100 bolt patter
http://i301.photobucket.com/albums/nn63/Supaflyw00t/Moonwalk.gif
Old 09-26-2009, 09:28 PM
downhiller's Avatar
livin large
unless someone did a 5 lug conversion on your car. that seems to be popular. but other cars you can get rims from are the vw jettas with 4 lug, minis, or you can oeder customs with the correct spacing and lug pattern
Old 09-26-2009, 10:17 PM
was probably from the mid 80s starting on the E32/34, but seeing as the E30 was already in production they wouldnt have changed it. thats my speculation anyways
