Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 09-14-2009, 07:47 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Lifted Jeep,240z
sounds like the T-stat is stinking +1
i'll trade you problems man... my car wont hardly go above the blue line and my fuel economy is also terrible lol
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
Old 09-14-2009, 01:17 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
ill give you half of my engine, and ill have half of yours and that is 100% gaurneteed to fix the problems for both of us
Old 09-14-2009, 08:13 PM
downhiller's Avatar
livin large
yours sound like the tstat is sticking open. could be same issue just different effects. it can happen
Old 09-14-2009, 11:33 PM
East Bound And Down
ok which half of my motor do you want.. its free, u just have to pay shipping
Old 09-15-2009, 02:32 AM
well you have the e... so you keep it on second thoughts lol
on a serious note.. what sensors should i test/replace?
Old 09-15-2009, 07:39 AM
East Bound And Down
the brown connector on top the thermostat is the temp sensor for the dash... i guesss start there.
the blue connector goes to the ECU and if its malfunctioning your car wont run so im assuming its not that one
Old 09-15-2009, 06:44 PM
checked and replaced both of those to no avail. if i pull the oxygen sensor, apart from leaving a hole in the exhuast system, will this indicate a bad sensor if the running temperature drops? or is this just a bad idea?
Old 09-15-2009, 06:51 PM
downhiller's Avatar
livin large
just unplug it. there should be a connection in the line near the o2 sensor, or in the engine compartment down by the exshaust manifold
Old 09-15-2009, 09:22 PM
i had a senior moment just then. ima go do that now, and then test it when i go to look at the 326i i mentioned in my other thread
Old 09-16-2009, 05:52 PM
downhiller's Avatar
livin large
is that when you get a brain fart then remembered you needed to change your "depends?"
Old 09-17-2009, 02:34 AM
thats teh one! lol
the oxygen sensor is unplugged.. still is and ive driven to school and back twice and the work as well... temperature is still high. i saw someone mention wait till it gets "overheated" and then turn the car off and then back on straight away.. the temp gauge does drop back to half, but within 30seconds its back to 3/4. i would swap clusters but iver taken my spare apart reay to accept the euro speedo i aquired (MPH)
does anyone think the fact that the fuel gauge is dodgy will be the same cause?
Old 09-27-2009, 04:51 AM
replaced the gauge and now the temperature reads fine, so that must have been the issue. noexceptions you should give that a go
