Old 09-29-2009, 01:14 PM
alex 540i's Avatar
alex 540i alex 540i is offline
Mein Auto: 97 540i/6
How do I open my trunk? No power.
So I took out my DME to send out to powerchip and locked the trunk with the negative cable unplugged, now I can't open it to connect the cable, the DME is not back yet but I don't think it will open even if it's connected... So, how do I open it? Key doesn't open it either...
Old 09-29-2009, 01:17 PM
MatWiz's Avatar
MatWiz MatWiz is offline
Psychology Reversalist
Mein Auto: 528
Put the key in, turn it until it stops, and then continue to turn about 1/5 of a turn. It has some resistance, so you think you can't.
The key will be parallel to the ground, just like when you lock the trunk, but to the other side.
mw
MatWiz
"The greatest thing about the internet, is that you can quote something and totally make up the source." - George Washington.
Old 09-29-2009, 01:42 PM
cn90 cn90 is offline
Read the owners' manual.
Old 09-29-2009, 01:45 PM
Darkflame808 Darkflame808 is offline
Mein Auto: 1997 540i
Whenever a remote doesn't unlock doors or trunks on a car I always suggest using the key. I know it's kinda caveman tactics to use keys on cars with remotes but sometimes you gotta go back to the basics when technology fails.
Old 09-29-2009, 01:51 PM
Yep,
When all else fails, ride a bicycle LOL.... (nothing to worry about, key, battery, belts, alternator, cooling system, LCM, struts, shocks, oil, clutch, insurance etc.)
Old 09-29-2009, 02:07 PM
anton-sa anton-sa is offline
Mein Auto: Bmw e39 525i 2001
heres wot i did
here is what i did
i disconnected the battery as i was working on the car doors (which has airbags)
i then by accident closed the boot and for some reason i coudlnt open it with the key.
what i did was
1) took back seat out (yes the other doors were open)
2) made small slit with utility knife in fat red power cable...
2) connected this to another car battery,
3) used door catch as ground...
4) pressed remote to open boot.
problem solved
Old 09-29-2009, 02:12 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Exactly. Turning the key 45 will activate the electrical unlocking, fully 90 will unlock it. If it doesn't work one way, try the other way. You'll need a real key, not a valet key. Again, the owner's manual will be able to tell you which key you have.
Originally Posted by anton-sa View Post
here is what i did
what i did was
problem solved
You can not be serious.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 09-29-2009, 02:33 PM
02 330Ci's Avatar
02 330Ci 02 330Ci is offline
Mein Auto: Varies
here is what i did
what i did was
problem solved
There is a jump point under the hood, you could connect a quick jumper to which will give you power to the car. locks and remote will work.
Old 09-29-2009, 02:37 PM
CoreyMNK's Avatar
CoreyMNK CoreyMNK is offline
Corey
Mein Auto: 2000 528i Step 215K Miles
Just stick the key in the keyhole in the trunk and turn... Anton, you gotta be kidding!
Old 09-29-2009, 02:47 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
I don't think so if the Negative cable is not hooked up to the battery.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 09-29-2009, 02:48 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Instructions from the owners manual that's been posted many times on how to unlock the car when there's an electrical failure:
1. As others have previously mentioned...the door & trunk lock cylinders were designed to be opened manually by inserting the key and turning it COUNTER CLOCKWISE (to the left)...PAST the normal position that electrically unlocks the door or trunk.
2. You can use the jump start locations under the hood (if the doors aren't locked) to open the trunk...ONLY...if you have the trunk lock in the unsecured vertical position ( | )....if the trunk lock is turned to the SECURED horizontal ( -- )...then you're stuck because only another MASTER key will be able to unlock the trunk (that's any of the keys you have that don't have the GRAY head...that's the valet/service key which doesn't unlock the trunk or glovebox). The trunk release button and the central lock/unlock button will not open the trunk if it is in the secured position.
Q {BMW CCA Member #191509}
(SOLD)
Old 09-29-2009, 02:53 PM
QSilver7's Avatar
dj
If you supply power (12v) to the pos & neg jump start locations under the hood...you can remove the battery entirely from the car and use any of the electrical components.
Even if you supply 9volts to the cig lighter...you can undo the battery and not loose any of your car's setting.
(SOLD)
Old 09-29-2009, 03:08 PM
djfitter's Avatar
Good to know.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 09-29-2009, 04:10 PM
MatWiz's Avatar
Mein Auto: 528
We need more opinions.
mw
MatWiz
Old 09-29-2009, 11:29 PM
dj
Even if the negative cable was disconnected, the whole frame of the car is a common ground point. Just clamp the red jumper cable to the + port on the engine bay and clamp your negative to any part of the frame and call it a day.
I hope the OP wasn't serious about slicing the cable...That was more caveman then my suggestion of just using the key. LOL
Old 10-01-2009, 11:31 AM
returnofmike returnofmike is offline
King of Kool
Mein Auto: 2001 540i
ahaha this is seriously hilarious! just put the key in the lock of the trunk and turn it to the left, it opens. . . with a key as well. . thats what there for!
Get what you can, can all you get, guard the can
Old 10-01-2009, 11:39 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
Easy:
1) Smash small rear triangle window on passenger side
2)Realize that you are too big to fit
3)Smash regular rear side window on passenger side
4)Realize that though you can fit now, the trunk release button is on driver side
5)Smash driver side rear window
6)Realize you cannot reach the front seat from the back seat
7)Smash driver side window
8)Reach down and press release button
9)Realize button is electrical and does not work
10) Smash passenger side window
11)Crawl through and open glove box
12) RTFM
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 10-01-2009, 11:47 AM
QSilver7's Avatar
Originally Posted by returnofmike View Post
...just put the key in the lock of the trunk and turn it to the left, it opens. . .
{Don't think of this reply as picking on you...it definitely is not...but I find it a good example to bring up a point.}
I think many people really do try to turn the key to what they "think" is the left...and fail so they give up.
The problem is...their perspective of the LEFT may be the cause of the failure. Without any context and a different perspective...they may have a point of reference that the 6:oo position is the starting point...so if they turn the key to the left...they are actually turning the lock cylinder CLOCKWISE (which is in the wrong direction).
That's why I try to insert that the lock cylinder should be turned COUNTER CLOCKWISE...which means that the point of view is turning the key left from the 12:oo position.
(SOLD)
Old 10-01-2009, 12:14 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
i unlocked a mercedes this way, sort of. my landlord's e320 (really a POS car made by MB ever... even beats out the 2.3 190E's) had a dead battery and the driver's key lock was broken. the only lock working was the trunk and no fold down seats (where the battery is located). i rigged a jump box to the... trunk light and "charged" the battery for 15 minutes, just enough to get the pump to unlock the doors. yeah, charging the battery through a known circuit directly linked to the battery helps.
but in this guy's case, he would really need to use the one under the hood.
americandan.com
It takes a lot of work to be lazy.
Old 10-01-2009, 07:31 PM
ProRail ProRail is offline
&amp;quot;Clunker&amp;quot; *****
Mein Auto: 1999 BMW 528A-220K-traded
So you're saying that if they are lying on the trunk lid looking at the ground they should turn it to the RIGHT. Thanks. That clears it up nicely.
Old 10-01-2009, 08:07 PM
chucksrt chucksrt is offline
Mein Auto: 540i
This thread is funny because I ran into the same problem and had to just keep playing with things until I turned the key past the point I thought it should stop and it unlocked the trunk.
Old 10-01-2009, 08:55 PM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
I lube and exercise the manual lock/unlock on the doors and trunk each time I change the oil. The manual feature is so seldom used that it may become very stiff when you need it.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-01-2009, 09:07 PM
bowtie bowtie is offline
Mein Auto: 98 540i-6
That's what she said...
Old 10-01-2009, 10:47 PM
MatWiz's Avatar
Mein Auto: 528
2 more posts and we are on page 2!
mw
MatWiz
Old 10-02-2009, 05:10 AM
2k528i 2k528i is offline
Mein Auto: 2000 528iA
I can't believe there are 20 something posts about unlocking the trunk...LOLOLOLOL
2000 528i
