Old 07-31-2003, 12:17 PM
rflores2323 rflores2323 is offline
ROOKIE
Send a message via AIM to rflores2323
Mein Auto: 96 bmw z3
how hard to remove gauge cluster>?
is there a how to anywhere?? is it difficult?
Old 07-31-2003, 01:21 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Why do you need to remove it?
There might be a how to in the archives. Either here or at Scrotefly.
The ham-and-egg way to remove it:
1. Disconnect batt
2. Remove qty 2 torx screws
3. Wrestle cluster out of dash pod.
4. Wire harnesses have an over-center latch design to make sure they never come loose.
The high-end way to do it:
1. Disconnect batt
2. Put down blue tape on black plastic around cluster to prevent scratch-master
3. Remove airbag
4. Remove steering wheel
5. Remove driver's knee bolster.
6. Remove structure behind bolster.
7. Remove 2 torx screws.
8. Push cluster out from behind.
9. Disconnect wire harnesses.
Installation is reverse of removal in both cases.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 07-31-2003, 01:28 PM
JonM's Avatar
Moderator
Here is a how to with pics from TimUK's site. I am adding his site to the FAQ post so if you have not browsed his site, please take a few minutes and have a look. He has a few how-tos under "Tim's Custom Gallery".
Jon Maddux
Old 07-31-2003, 02:54 PM
ROOKIE
that is exactly what I wanted.!!!!! thanks!
