Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 10-10-2009, 06:15 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
850i Top End Engine Rebuild
I'm rebuilding the top end of a five liter v12 (850i) at work, and thought I would post some pictures of the progress just to show you guys. Enjoy.
Stock OHC and Rocker Set Up Makes A Nearly Hemispherical Head
Three Thou Skim
Don't Even Want to talk about the labour to re&re the engine
Old 10-10-2009, 07:00 PM
HyphE36's Avatar
HyphE36 HyphE36 is offline
Search Button Upper Right
Mein Auto: E36 95 325IS Black/Black
Awesome Corey
You're the man!
Looking for a nice classic 2002, 1972-75 preferred
. SOLD
MEMBER OF THE MOST EXCLUSIVE SECRET CLUB ON THE 'FEST
Old 10-10-2009, 07:23 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Good job!!! Thats a pertifull motor
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 10-10-2009, 07:52 PM
Route 66's Avatar
Route 66 Route 66 is offline
Mein Auto: 2001 740i
Lookin grea!t Keep us updated.
Old 10-12-2009, 05:52 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
very nice. and yes, i know how difficult these beasts can be to r&r.
thanks for thinking of us. i'm sure there are lots here that will enjoy a peek into the internals of the v12.
btw, did it overheat and pop a headgasket??
df
ps, i've got a v12 sitting in a barn waiting for the right 'recipient'...
Old 10-13-2009, 09:29 AM
FixItFaster
df
No it broke a couple of headbolts and turned what was the rad cap into a geyser
Was overheating alot before it came in and the idiot continued to drive it for two days. But we got it in took the heads off and got them skimmed and they only needed three thou!! So obviously these engines can take alot of heat ay.
Old 10-13-2009, 11:01 AM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
If the heads are still off measure the cylinder bores for roundness. They tend to oval at the bottom after overheating.
If it is a ways out a quart of oil every 100 miles or so has been one of the results seen.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 10-13-2009, 02:07 PM
FixItFaster
The head are ready to go on but not on as of now. The car was running before we started this and was not pushing blue out of the tail pipe, but with as much steam as there was it may have been hard to tell. Also the oil level was to spec before I started. But some very good advice, I will look into it to make sure this is not the case with this engine.
Old 10-19-2009, 02:29 PM
FixItFaster
Update:
Engine bore checked, and has acceptable taper.
Engine re-assembled and getting ready to go back in.
Old 10-23-2009, 05:15 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
looks quite interesting. who did you get the gasket sets from? ive strayed away from V12 cars. they are nice when they run, but a nightmare when they break. i guess if you have the money to maintain and service a V12, theres no worry.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 10-24-2009, 03:17 PM
FixItFaster
Gasket sets are from bmw, in germany. I hate the m70b30, but thats only because it was bmw's first attempt at something as high tech as this. It had many flaws, but it had many great innovations such as the first production engine with fly by wire throttle. It was also the first car to have problems with fly by wire.
However there are some bmw v12's I would give a leg and an arm for.. Like the BMW S70/2 from the mclaren. Of course this engine shares nothing in common with the m70, it is an entirely different block and design. In fact the 6.1L F1 engine shares more in common with the s50b30 engine in my car than the 5 liter v12.
FYI This particular customer has spent over 16g in maintenance in the past year and a half.
Old 10-24-2009, 04:37 PM
yeah, i figured it was something high. just not quite what i'd go for, as far as cost of maintenance. probably why you dont see an abundance of these machines running around. for that matter, not too many exotics in abundance. must be nice though to be able to own one. i'll stick to my reliable 4.4 liter.
*Der E38*
manufactured: 7/01
Old 10-26-2009, 08:29 PM
semaj1 semaj1 is offline
Mein Auto: 1996 740il
E38 Head Gasket change
Sarting head gasket change do you have any tips on disassemble or reinstalling heads? I will be tackling this job myself and can use any help that I can get.
Thank you.
Old 10-27-2009, 09:24 AM
FixItFaster
I wouldn't call the 850 exotic. But thats just me, that cost was not just for this job btw.
Old 10-27-2009, 09:28 AM
FixItFaster
Thank you.
If you have no experience of this sort I say don't even think about it, you could cost yourself alot of money with the smallest error. Why is it you are doing this?
Old 10-27-2009, 04:20 PM
yeah heads i wouldnt recommend tackling unless you've done some before on a 4.4, you will have trouble getting the timing right and will likely have it in a shop at the end. good luck with the timing though, its a pain if you havent done it before. its not like older vehicles in a few ways.
*Der E38*
manufactured: 7/01
Old 10-28-2009, 10:55 AM
Slick44 Slick44 is offline
R.E.44
Mein Auto: 2011 BMW 750i/2007 750i
wow!
