X3 E83 (2004 - 2010)
Window Regulator Repair done
FYI
I did my friends 2004 X3 window regulator repair for both rear windows (only one was broken, but I dont want to do it again, so do both at once). Simply replaced the drive dog, instead of the entire window regulator module. $100 for two drive dogs, and $30 for two vapor barriers. First one was a pain and took long until i realized you should move the drive dog up and down to easily remove the window and the dog itself from the rail. 2nd window took about 20min. A note, replacing just the dog itself is faster then the entire regulator module, and also cheaper =) My vapor barriers are on order. I decided not to risk my friend complaining of water leaks and simply ripped off the old barriers. It took quite a while to remove the barriers from the gooey stuff. I have Permatex silicon adhesive/sealant purchased at local pepboys to reseal the barriers. The gooey stuff has dirt indicating where the water would tend to flow, so this should make identifying where to ensure I reseal correctly. The old gooey stuff is still on there, so that should provide something to hold the barriers as the seal I apply cures. The windows require manually going all the way and all the way down to re-learn the thresholds for auto up/down functionality. I was confused at first, but figured it out. Drive Dogs are : http://www.realoem.com/bmw/showparts...=51&fg=10&hl=3 Items 51333448643 and 51353448645 Last edited by bluskye; 10-29-2009 at 01:37 PM. |
Update with Butyl Tape part number from dealer. Some may not know you can purchase it.
Butyl Tape : 83190153321 Scape off old tape as good as you can with utility knife. Doesnt have to be perfect. Apply new tape over old residue. Warm the tape up with hair dryer. Apply Vapor Barrier over the tape. Continue using hair dryer over the edges and press firmly. Keep doing it over and over, the tape will get hot and tacky. Test by leaving off door panels and use a hose to spray window(s) to ensure no leaks through the vapor barriers. After the leak test passes, you can put back on door panels Last edited by bluskye; 12-05-2009 at 05:10 PM. |
I actually have the same car as your friend, and just a few months ago I had to replace the driving dog on my driver's side rear window. It was weird how it just broke... I looked at it after and it seems like rather poor design and build quality, at least the part is "sorta" cheap, I guess. Anyway, I looked up the parts really quick... www.realoem.com is a great site. My local dealer ordered the parts and I was on my way same day.
I kept tho old vapor barrier, BMW uses this sticky black stuff to seal it and it the same stuff I use at work so I know how to work with it. FYI, the stuff softens up and bonds back together perfectly if you heat it up... hairdryer is pretty quick. The hardest part to start with was figuring out how to remove the door panel without breaking any of those plastic clips. My old 525i, was really sensitive, I could never remove the door panels with all pins intact. In the X3's case it was actually extremely easy, just got to know where the pins are. The driving dog itself was a bitch, but luckily I only had to do one door. |
Hi all,
my 2006 X3 Rear passenger window just broke. When the passenger pushed the window button, it did now sound right, like a rattle noise. She had the window half way down and was not responding when she tried to roll it up. However, she was able to roll the window all the way down, but now it won't roll up. Is this a regulator issue as well? Please advise. |
Senegyh,
It is very likely to be a regulator or just a drive dog. You need to take off the door panel and take a look. Cheers |
Sen, you are probably still under warranty or just out of it, take it to the dealer and see if they will fix it under BMW's recent liberal "good will" warranty policy. There is a good chance they will fix it free since it is a well known problem because of poor quality material (drive dogs). Worth a try anyway.
SI B 51 16 06
Body Equipment Window Regulator Not Working or Noisy MODEL E83 (X3) up to 04/06 SITUATION The customer may complain of a power window that will not operate or is noisy during operation. CAUSE The white plastic slider on the window regulator may be damaged. CORRECTION On a customer complaint basis, replace the damaged window regulator slider with the updated slider. The updated slider, which was not available previously, is an improved part, made from a different material. PROCEDURE Remove the damaged window regulator according to repair instruction RA 51 33 000 (Front) or RA 51 37 000 (Rear) If only the white plastic slider is damaged, replace it by using the following instructions. If any other damage to the regulator exists, the entire regulator must be replaced. Note: The front window has 2 sliders and these should be replaced in pairs
Kevin ----- 2009 MINI Cooper Clubman - "Oxley" Nightfire Red/NFR, Tuscan Leather, CP, PP, CW, Roof Rails & Aero Kit, 16" Bridge Spokes, Xenon, Auto, English Oak Trim & Wood Wheel, Alarm, Hi-Fi ------- 2007 Volvo S60 2.5T 2007 X3.0si PlatBronze/Beige 2006 X3 3.0i, Flamenco Red/Beige 1997 528iA, Oxford/Tan 1994 318iS, Black/Gray 1979 528iA, RubyRed, Tan 1971 2002, Sahara, Saddle |
We had both windows on X3 2004 - drop in tracks. BMW charged us 400.00 per window.
We are not mechanics. HAs anyone had any communication about BMW 's resonsibility on this? First time ever, a in operative window --both sides. Our Car was out of warrenty, it sucks. |
Reasoning? Seems like they were using a softer material for the plastic (teflon) drive dog on earlier models, which is what breaks. It took me about 30-45 mins to do one. My cost: $75.00 If you really don't feel comfortable taking things apart, find a reputable independent shop in your area,(www.bimrs.org) labor rates at the dealer are outrageous. |
When you say DIY for window regulator replacement or driving dog replacement ....where is that ?????
BMW X3 FAQ and DIY compilation (http://www.bimmerfest.com/forums/sho...d.php?t=457330) In that thread, under Miscellaneous Documents, you will fingd a PDF for "Rear window repair". Note that when wanting to obtain just the drive dog, some parts departments may know it by a different name, such as "traveler" or something. The dog analogy comes from the work that item does as part of the regulator assembly in fetching and carrying the window glass up and down. |
Hey guys...my wife is out of town and heard a "pop" while putting up the left rear window. It made it the rest of the way up...is there a chance that the window will drop now before I can replace the drive?
Thanks |
It depends on what exactly happened, but you cannot know until you take a look. When she comes home, give it a try. If it doesn't work, you
need a new drive dog, or you can try to repair yours. |
I'd advice her to get a roll of painters tape and tape the glass along the top to avoid it to roll all the way down, once there you need to disassemble the door interior to bring it up (and to repair/change). |
Thanks for the help...painters tape is holding it up until I get the parts.
What tools are needed to fix this? My tool inventory doesn't include many auto tools Last edited by Blue Monk; 11-01-2010 at 03:48 AM. |
Nothing special...just assorted screwdrivers, and I used a small ulphostery/clip removal tool to start the cardboard off. The job is really easy, it seems more complicated than it really is.
There are a couple of guides on the DIY sticky, the one mentioned above and on entitled "Door Panel Removal" this is the step-by-step instructions, and kenza's pics in the other document is a good compliment, I used both. Last edited by X3-terrestrial; 11-01-2010 at 06:03 AM. |
So far so good but I'm having trouble pushing in the tab and releasing the window...any suggestions
It took me several attempts to be comfortable with the amount of pressure. Good luck. |
Holy moly...I finally got it. I was nervous about pressing against the glass. Having another set of hands definitely helps.
Thanks for all the help!! |
Oh yeah! Nothing feels better than saving money!
Might as well do the other side if you plan to keep the car a couple more years. It will go out. Second time should be really fast once you know the tricks.
Today I got the outer panel off on my 2002 525 and wrote an ad-hoc DIY: - How to remove the outer door panel on a 2002 BMW 525i But, before I finished, I got stuck on the NEXT step. - What's the NEXT step for removing the door panel to diagnose broken window regulators What's the next step after the outer panel is off? - Do we remove the airbag? - Do we remove the speaker? - Do we just start peeling the vapor barrier off from the bottom? |
#25
Hi! Just remove the vapor barrier. BTW, before you do anything, disconnect the battery to avoid any problems with the airbag exploding into your face.
