Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 07-26-2009, 09:33 AM
vmijj91 vmijj91 is offline
vmijjg91
Mein Auto: 2001 BMW 740IL
2001 740il oil filter o-ring
On two occasions about a month apart i have had the o-ring on the oil filter housing blow by and have to be replaced. Has anyone had this problem and if so is it an indicator of another problem.
Old 07-26-2009, 02:26 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
What kind of filter? Some people have recently reported problems with non-OE filter kit o-rings not being quite the right size and causing leaks. Just to check, I'd try a real BMW one from the dealer next time and see if it seals up better.
I've not had the problem with Mahle or Mann boxed filter kits, but it might be worth trying a BMW boxed one just in case.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 07-27-2009, 12:37 PM
vmijjg91
Thanks, I will try that.
Old 10-29-2009, 01:48 PM
sundlh sundlh is offline
Mein Auto: 2001 4.4 X5
Wink Oil Leaks at Filter housing
I have a 2001 X5 with the 4.4 engine. On two occasions I have had leaks when I used Purolator filters with their undersized o-rings. The leak would only occur when the temperature was below freezing and would stop once the oil / engine temperature rose enough to expand the o-ring. Do not use Purolator o-rings on a BMW!
