Old 07-29-2003, 02:18 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
M Coupe rear Liscense mount removal?
Has anyone thought about pulling off the surround for hte liscense plate on the M Coupe? With those two lights on either side? How much trouble would it be to pull it off? Would there still be a way to mount the liscense plate up there?
B
Old 07-29-2003, 03:59 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
B
It's easy to remove for cleaning. Remove your plate, then remove 4 bolts. Done. The wire harness for the lights comes through the hatch in one large hole with a rubber grommet. It is not easy to re-install after cleaning. BMW uses wellnuts. The wellnuts have a habit of falling inside the hatch upon re-installation of the mounting bolts. Then you have to fish them out. Then you have to find replacement well nuts. Can be a real PITA.
We use wellnuts on Mk3 MINI Cooper armrests. They are great in 1-use blind applications. Not in multiple or annual cleaning applications.
I don't think the holes in license plates match the holes in your car. I assume that's what you're asking about... deleting the panel and the lighting entirely.
Jon Maddux
10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe
Old 07-30-2003, 02:20 AM
Anders Anders is offline
Dare to be different
Mein Auto: BMW X3 35D
I always thought that the rear of the US MC looked a little bit messy (no offense here!), at least compared to the Euro MC.
http://www.geocities.com/bmw_z3_m_coupe/100_0627.JPG (copy and paste link)
I understand the reason behind, i.e. the large square number plate used in the US, and that this would cause problems size-wise with the Euro style rear.
I don't know how involved it is to change to the Euro style, easiest would probably be to source the entire rear hatch door?
Also, a little bit OT, I suspect that the problem a lot of US MC owners have with the failing latch mechanism could be due to the redesign for the US market - I have never heard about failing Euro latches.
Anders
'08 BMW X3 xDrive 35d (Titan silver / sand-beige leather)
ex '09 MB C220T CDI (black / black)
ex '95 BMW 320i Touring (black / black)
ex '02 BMW M5 (Carbon black / black)
ex '01 BMW 530D Touring
ex '98 MB C43 T AMG
ex '99 BMW M Coupé
ex '93 Alfa Romeo 164 24V
Old 07-30-2003, 09:21 PM
JediZ JediZ is offline
Mein Auto: 2001 Z3 Coupe 3.0i
The US Z3 3.0i coupe has the same rear hatch door as the Euro M coupe. Or at least it appears so.
Old 07-31-2003, 05:30 AM
Mpire's Avatar
The Anti-Rice
Yeah, but the 2.8 and 3.0 coupes are even rarer than the M coupes.
But I will start putting feelers out.
B
Old 07-31-2003, 06:56 AM
B
You could always buy the Z trunk (liftgate) from the dealer.
41628400025
$406 without glass
Old 08-01-2003, 07:05 AM
bolewis bolewis is offline
Mein Auto: M coupe
Nutserts
You can buy "nutsert" kits from various vendors. You could drill holes from your license plate as a template and use the nutserts to bolt your tag to. You could also use the nutserts to replace the BMW wellnuts if you keep it the same. They don't wear like the BMW ones which fall off inside the rear hatch lid.
Link for Nutsert Kit at Eastwood Company
Bo Lewis
Old 08-01-2003, 01:47 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
41628400025
$406 without glass
The M coupe lid is 41 62 8 411 102 $406.00 retail
The Z coupe lid is 41 62 8 400 026 $599.00 retail
Old 08-01-2003, 02:30 PM
Mpire's Avatar
The Anti-Rice
Assuming I was crazy enought to invest $1000 for a tailgate, glass and painting just to get the regular Z tail gate....
Then where would I put the liscense plate? Cut it down to size a bit and hope no one notices?
Where do the euro M Coupes put the liscense plate?
B
Old 08-03-2003, 04:43 PM
B
Euro Ms mount the plate under the chrome lift lever, since it is skinnier it fits perfectly. US style won't fit in this location so I don't know where you would put it.
Old 08-04-2003, 07:37 AM
Mpire's Avatar
The Anti-Rice
But HOW does it mount?
B
Old 08-04-2003, 09:17 AM
zanary zanary is offline
Mein Auto: 1999 BMW Z3 Coupe
Here's a side by side shot of a Z3 and M Coupe (US Spec)
