Old 11-07-2009, 05:46 PM
Zoltar's Avatar
Zoltar Zoltar is offline
Your Wish Is Granted
Mein Auto: 2009 X3 MT
Question for '07+ MT Owners Regarding Clutch
Hey all,
I noticed something today and wondering if it's normal or not.
When sitting idle with the clutch pedal not depressed I hear a slight shudder/rattle coming from underneath.
When you press the clutch pedal it goes away.
Shifter is in Neutral.
It's not a bad sound like grinding and not all that loud but it is there.
It sounds like something shaking.
I really notice it in the garage where the sound is bouncing off the wall and therefore more noticeable.
Thanks.
Old 11-08-2009, 09:36 AM
madurodave's Avatar
BMW Enthusiast!
I don't have a MT X3, but I had a MT Z3. Same sound. That sound was always there. The pressure plate rattles slightly when not under compression. I personally would not worry about it, but have not heard it on you vehicle. You could always have the dealer do a quick listen, but there is probably no issue.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 11-08-2009, 10:07 AM
Zoltar's Avatar
Thanks, I thought it was something like that.
It does not sound like anything serious but rather curious.
Anyone else notice this?
Old 11-08-2009, 04:10 PM
Zoltar's Avatar
50 views and 1 reply.
I guess I should have said I hate my X3.
Old 11-09-2009, 09:10 AM
T1T2GRE T1T2GRE is offline
Bleed blue and white
Send a message via Yahoo to T1T2GRE
Mein Auto: 2011 1 Series M Coupe
+1.
I've heard this on all of my vehicles to some degree (all are manual), including 1986 Bronco II (stop laughing, it got me through college), 1984 318i, 2002 Jeep Liberty, 1996 SC2, and 2008 Sky Redline.
None of them were worse for the wear.
"You will have goosepimples." - Kay Segler, Ph.D.
Old 11-09-2009, 10:12 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is online now
Aficionado
It happened to one of dad's company pickups, it was a 88 Isuzu. Ended up being a clutch bearing.
Old 11-09-2009, 10:41 AM
Aficionado
Clutch noise is another problem that may be tricky to pinpoint. If a squealing or chirping noise appears or goes away when the clutch pedal is depressed, the cause may be a bad release bearing. Other causes include a bad pilot bushing, a worn or defective input shaft bearing in the transmission, a worn, bent or improperly lubricated release fork, a worn input shaft, improper disc installation, misalignment, damaged bearing retainer, loose flywheel bolts, damaged disc splines, or worn stop pins or broken damper.
A growling or grinding noise when the clutch is engaged may be due to a bad transmission input shaft bearing.
A squealing sound that occurs when the clutch pedal is depressed and held is usually caused by a bad pilot bearing or bushing.
A chirping noise that intensifies when the pedal is slowly depressed would indicate a bad release bearing.
If you hear chirping while idling in neutral and the noise goes away when the pedal is slowly depressed, the fork/pivot ball contact point is making the noise
http://www.aa1car.com/library/2004/bf40459.htm
Old 11-09-2009, 04:48 PM
Zoltar's Avatar
Old 11-09-2009, 06:47 PM
kenza kenza is offline
Mein Auto: 2007 X3 2.0d MT
Well, I do not hear anything on my car as the diesel engine itself makes noise, so the cluch is almost impossible to hear
