Old 03-13-2009, 01:01 AM
Leonardo629 Leonardo629 is offline
Mein Auto: '13 E92 M3
Z4 Door striker bolt torque spec
can someone post the torque spec for the door striker T40 bolt? I want to adjust them so the windows pushes on the rubber strip abit more...the driver side window began to squeak 3 days ago.
thx
Old 03-13-2009, 07:17 AM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S65B40 Powered
You may want to try picking up some Krytox off amazon and rub it well into the seals after cleaning them. Adjusting the door striker may cause other undue problems. Here's a link to the Krytox:
http://www.amazon.com/C-R-Laurence-K...6953742&sr=8-1
This is the same branded stuff used by the Chevy dealerships for their squeaky roof panels in the Vette as well as the Volkswagen dealerships for the $hitty EOS roof panels. I applied it last October when I first got the Zed and have been squeak free, it really keeps the seals moist.
08 E90M3 6MT Alpinweiss/Schwartz
Old 03-13-2009, 05:11 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
thx
If you want to adjust the window inwards at the top, there is an adjustment bolt at the bottom of the door covered by a plastic cap. This bolt moves the bottom of the window track in or out over a range of about 10mm, causing the top of the window to move in the opposite direction against the window seal.
Old 03-17-2009, 11:27 PM
thanks for the replies guys!
Old 11-23-2009, 05:24 PM
afhf0508 afhf0508 is offline
Mein Auto: 2003 BMW Z4 2.5 5spd
Also have a small air/water leak, did an adjustment on window on the driver side it got better but over a month the wind noise is back.
Based on recommendations on this post and reading around I did to get the Krytox High-Performance Lubricant. it came out to $44, not cheap but if the wind noise goes away well worth it.
I will post updates after it arrives and I apply it.
