Z3 Differential tool
Where do I find a 14mm differential tool...in other words a 14 mm hex (allen)head socket 1/2 inch drive for a "reasonable" cost?? I am about to change the diff. fluid and replace with a redline product. Maybe someone has one f/sale?? Please advise. Thanks!!
I found mine @ Autozone.
Still had to cut about 1/2" from the hex so I could use a rachet.
96 Z3 1.9 Black/tan/black 97 M3/4 Estoril/dove gray 08 3400HST Kubota Orange/gray 08 GMC Sierra CrewCab |
Just DO NOT tighten them upon reinstallation to the factory torque spec of 75Nm. Several people have cracked the cover BEFORE reaching that value.
I only tighten them to 45-50Nm, and haven't had any leak, crack or come loose in the past nine (9) years. Buy two (2) new replacement sealing (crush) washers and reuse your existing plugs.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Got mine from Bavauto, send me a deposit, I'll mail it to you and refund your deposit upon return. Forgot to mention is a 3/8"
http://www.harborfreight.com/cpi/cta...emnumber=98229 Sears also sells these on-line. See following link: http://www.sears.com/shc/s/search_10...hex+bit&vName= |
FACOM from Ultimate Garage
http://www.ultimategarage.com/shop/p...roducts_id=890
Jim Millet 2007 Imola Red Z4 M Coupe' Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates. |
Not many will pay for that.
Guide pin socket
STAHLWILLE SOCKET.
I got the tool at sears.
Does your clutch still have the squeak? |
That was certainly the first one I knew about, but several more since then, judging by the number of people that have wanted the take-off ///M covers. These were owners of ///M cars, not Z3s doing updates.
Gentlemen,
How crucial is it that a "stuby" socket be used? If that is the case then I should be looking at the Facom tool or the Stahwille. But do they have them in a 1/2 in. drive cause that's the size of my torque wrench. Please advise. Last edited by morrieschoice; 11-23-2009 at 08:10 AM. |
Nothing but a "stuby" socket will fit, specially with a torque wrench.
Ron, can the Stahwille socket be purchased in a 1/2in. drive (my torque wrench is that size) and where can I get it? Please advise. Thanks!!
The FACOM is a 3/8" 14mm for the diff. The STAHLILLE is a 3/8" 7mm for the caliper guide pins. ...................................... You need more than one torque wrench if working on a car. I have a 3/8" - 25 > 250 inch pound one along with a couple of 1/4" lower inch pound ones. I have a 3/8 - 5 > 80 foot pound (one I use the most) I have a 1/2" - 25 > 250 foot pound (lug bolts) ...................................... If you have the room you could use your 1/2" torque wrench and a normal 14mm hex socket. http://www.unofficialbmw.com/e36/dri...id_change.html . . Last edited by Ron Stygar; 11-23-2009 at 11:19 AM. |
Unlike the E36 the E36 Z3 M Roadster/Coupe does not have a clearance issue with the top (fill) differential plug, therefore, you don't need a stubby socket. Clearance is also not an issue with the side mounted differential plugs on the Z4M. The Z4 transmission plugs are a different matter. They require an 8mm hex and the top (fill) plug has minimal clearance. I use a Matco stubby 8mm hex P/N BXYS8M to access the top plug with a torque wrench.
Less than the Snap-on one. What's the over all length?
Thanks for everyone's advice/help...today looked at 3/8 socket wrench....think I will go with that and get the Facom 3/8 hex socket....much easier than trying to find a 1/2 in socket to fit my torque wrench.
