Camber correcting bolt Location Z4MC
Hey guys,
Due to a lot of helpful info on this site, I have ordered and received my camber correcting bolts from Turner that I'm going to install on my Z4MC. My only question is WHERE to install them. Does anyone have a picture of their installation location or some direction you can give me. Thanks! |
This is an old thread that discusses those bolts.
http://www.bimmerfest.com/forums/sho...ht=camber+bolt Make sure you torque the bolts to 81 NM and use loctite on them. The factory uses red (high strength) thread locker. |
I believe that Mr. H. stated that each washer is good for about 0.5 degrees of negative camber, unless I am remembering that wrong. |
I just got finished with the install and it was pretty simple. The existing bolts were easy to break free but a little hard to back out. I have a long torque wrench that did the trick but is a little hard to manuever. But, oh wow, what a difference!! ). I haven't tried it on the track yet, so I can't really do a complete eval but I'm sold already!!I highly recommend this.
Done, Done and Done on your three pieces of advice! Correct on the .5 degress of neg camber. I used 2 of the washers on the outside and should now have 2.5-2.7 degrees of neg camber. Whatever it actually is, it's perfect! Thanks again for finding this old thread!! |
Don't forget to check front toe after you've changed the camber. Factory spec for the Z4M is 0.16 degrees plus or minus 0.1 degree. I like my front toe at zero.
Jim Millet 2007 Imola Red Z4 M Coupe' Premium Package, Nav, HD Radio, Heated Seats, CDV Delete, RPI Scoop, Strong-Strut fire wall braces, TCK DA Coil Over Suspension with Camber/Caster plates. |
http://www.turnermotorsport.com/html..._ID=TSU3690036
I emailed Turner months ago to tell them that it works just fine and they emailed me back to tell me they don't LOL. They're obviously confused
+1 on Turners obvious confusion!!
