Old 11-24-2009, 09:56 AM
DanTheMan7 DanTheMan7 is offline
Mein Auto: 3X Black 3.0 Z4 6SPD
Z4 Hood Won't Open
Can anyone provide guidance on how to open the hood of a Z4? I went to replace the wiper relay because my wipers are acting up and the lever refuses to open the hood. I have heard a long screwdriver or pliers work but need some opinions. Please help...
Old 11-24-2009, 11:00 AM
Bill_R Bill_R is offline
Mein Auto: 2003 Z4 3.0
Please don't attack it with a screwdriver! I've never had to do this, but I've heard that if you have someone gently press down on the hood while you pull the lever it will release. The problem is that the mechanism needs some lubrication, so do that while you're in there fixing your wipers
I've also heard that if you can find a good looking woman to gently rest her behind on the hood while you pull the release that this will work also.
Bill
Old 11-24-2009, 05:46 PM
RufusKing RufusKing is offline
Send a message via MSN to RufusKing
Mein Auto: Z4 3.0i Roadster
Bill
I don't know about the hood but that sure would work for me... hahaha
This one is called OPey
2009 BMW Z4 sDrive 3.0i
I call her weezey
2006 BMW Z4 3.0i Roadster - Sold and I miss her.
Old 11-25-2009, 03:58 PM
Mario Free Mario Free is offline
Mein Auto: Z4 3.0i Sport
WD-40 the latches that should keep it working well once you get back in it. (Assuming the wire did not break) If the wire is broken check the boards since a while ago I saw a how to DIY on changing it out, but did not look like a fun project.
Old 11-26-2009, 11:30 AM
nlink720 nlink720 is offline
Mein Auto: 2004 Z4
This happened to a friend of mine.
I held the hood release lever while he tapped the top of the hood right where the latch mechanism (dead center of the hood near roundel emblem) and it opened.
This is the solution, especially if you had been tinkering with the hood height position adjusters
Try it, just don't bang to hard on the hood, but you will need two people, one to hold the lever inside, and you to gently, but firmly tap the hood.
FS: Leather Recaro Pole Position Seats & Hardware
