Old 11-27-2009, 09:40 PM
stairwayto7 stairwayto7 is offline
Pittsburgh Steelers Fan
Mein Auto: 325i & 528i & 33ci
Air bag lite
New guy! My air bag light is on. How to fix it. (1998 528 BMW)
Old 11-27-2009, 10:35 PM
atrovarious's Avatar
atrovarious atrovarious is offline
Mein Auto: Black 1997 528i
Question
Mine is too.... I thought it was because I had some weight on the seat... not the case though...
Old 11-27-2009, 11:34 PM
frhsfootball80 frhsfootball80 is offline
looking for a car
Mein Auto: e39 m5 & 92 civic
for the OP, you will have to check what its for, as for the second guy, you ruined your seat occupancy sensor in the passenger seat.
the sensor is really sensitive and when it goes bad the airbag light is tripped. its not "dangerous" because in the even of a crash the passenger airbag will deploy now as well. compared to if the light was off only the driver side would deploy.
fixing it is a pita because its inside the seat.
best of luck
-R
Old 11-28-2009, 09:57 AM
xraye39 xraye39 is offline
Mein Auto: 530i
You can read airbag codes and reset with Carsoft, Peake SRS tool, BMW diagnostics software or the dealer.
SRS light can not be reset by disconnecting battery.
Common causes of SRS problems are passenger seat sensor mat or unplugging SRS connector without disconnecting car battery.
I had a 525i that the airbag light tripped on. I figured I might have tweaked the passenger seat sensor mat with my left elbow while checking out fuses in the glovebox. I used Carsoft to clear SRS light and it never returned. YMMV.
Old 11-28-2009, 01:19 PM
nike001 nike001 is offline
Mein Auto: 04 330 ZHP
Something happened to the passenger seat of my car, which tripped the airbag light. Dealer wanted $750+ to fix. needless to say..the light is still on..
330i ZHP 6MT | H&R Sport Cup | BMW Performance | OE Clears | Coby Wheel
Old 11-28-2009, 01:34 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
junk yard parts are nice.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 11-28-2009, 01:48 PM
jfive96 jfive96 is offline
Connections Etc.
Send a message via MSN to jfive96 Send a message via Yahoo to jfive96
Mein Auto: 1998 528i
- -Mine came on after I was cleanning uder the seat with my shop vac- -
[SIGPIC][/SIGPIC]* *Guns Don't Kill People, Crazy Mutherf*%$ers Like Me Kill Theives!!!!!!* *
"Connections Etc." I got what you need! Get at me!!!
I'm Rich B@*#$h!!!!
Old 03-04-2011, 05:05 PM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
Check under your seat and ensure all wires are connected and the harness is connected to the underside of the seat and not on the floor. Reset the codes and you should be sweet.
Sent from my iPhone using BimmerApp
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 03-05-2011, 10:33 AM
Spencercat Spencercat is offline
Mein Auto: '03 540i/6
If its the passenger seat sensor then there's a $5 Radio Shack diode fix out there. Search around a bit and you'll find it (I think on Roadfly). I did it to mine and it worked great. Make sure that you unplug the battery before taking the seat out though.
You will still need to reset the SRS code with a SRS scanner or some such before the light will go out of course.
Sent from my Droid using Bimmer App
Old 05-27-2011, 12:17 PM
I have never used any of these tools (as my SRS airbag light has never gone on because I use more garlic than most of you) ... but these links should help:
- What can cause an SRS airbag light (1) (2) (3) (4) (5) (6) & what tools reset the fault (1) (2) (3) (4) & what happens when window regulator fixers disconnect the airbag before the battery or they connect the battery before disconnecting the airbag (1) (2) (3) & where to buy an airbag occupancy sensor bypass unit (1) (2).
Old 06-01-2011, 05:57 AM
macgy macgy is offline
Mein Auto: E34 M50, E39 M52, M54
My car's airbag light is coming on then it go off after a while, it doesn't happen that frequent but it has been this way for the past 1 year, I have yet to be able to resolve the problem, suspect faulty connector but don't know which one! now that i read this post, I am going to check the connector under the seat.
Old 10-25-2011, 05:13 PM
For the record, here's a suggested airbag tool:
- E39 (1997 - 2003) > Airbag Light came on after regulator repair
Originally Posted by DustinSB View Post
Hey all -
I fixed my airbag light using a cheap part I bought on ebay from Hong Kong for $30 delivered (took about a month to get to me). It worked on my e46 and included the e36 adapter. It just plugged in and hit reset and I was good - couldn't have been easier.
Just go to ebay and search "B800 SRS Airbag Light Reset Scan Tool for BMW E36 E46". Beats the $100+ dealer and specialized parts I see discussed in these forumns.
Cheers -
Dustin
Googling ... I find:
http://www.youtube.com/watch?feature...&v=IhotCWklEfk
Old 05-02-2015, 02:47 PM
Typing /airbag f3 in the bestlinks nets this...
- What is the cheapest usable BMW airbag srs reset/scan tool on the net (1)
See also:
- How do BMW Supplemental Restraint Systems (srs, airbag, bst, crush zones, etc.) really work (1) & what is the cheapest usable BMW airbag srs reset/scan tool on the net (1) & what other scan tools reset the fault (1) (2) (3) (4) (5) & what can cause a BMW SRS airbag light (1) (2) (3) (4) (5) (6) & a cn90 DIY for replacing the driver seat belt buckle pretensioner and the passenger seat emulator (1) (2) & where to obtain an airbag occupancy sensor bypass unit (0) (1) (2) & what happens when we disconnect the airbag before the battery or we connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) (7) (8) & a front window regulator autopsy report (1)
