Old 12-01-2009, 08:58 AM
Sunset Hogan Sunset Hogan is offline
Mein Auto: e46 325xi
Hard to press, squishy brakes!!
I have a 2000 528i with about 140k on it, and recently, after every rain storm, my brakes have been very hard to depress, they make an awful "squishing" noise, and it takes time for the pressure to build back up in the pedal. Around the same time that this started happening, my engine also started to act funny... Again, only after it rains, my engine has a terrible loss of power, feels like it is only running on two or three cylinders, and emits a lot of white smoke out of the exhaust. It "bogs" down in the lower gears and is literally struggling to move. I spoke briefly to a bmw mechanic, who said it may be my vacuum booster causing both problems. A friend of mine, who is an Audi mechanic, said it may be the master cylinder causing the braking problems, and bad ignition coils causing the engine problems. I tried to silicone the coil heads, or whatever they are called, and also replaced the spark plug boots, but nothing has worked so far, and both problems seem to be getting worse! Sorry this is such a lengthy thread, but any help would really be appreciated!! Thanks!
Old 12-01-2009, 09:10 AM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
Probably a leak in the vacuum system. At that mileage it's quite common for the rubber hoses to crack.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 12-01-2009, 09:32 AM
cn90 cn90 is offline
Get some popcorn and coke and read this:
http://forums.bimmerforums.com/forum...php?p=17987958
Old 12-01-2009, 06:49 PM
Thanks for the tips! I'll get to cleaning out whatever crap is in there... As far as the hoses, is that an expensive/difficult fix? ive been trying to do most repairs myself.
Old 12-09-2009, 08:42 PM
zanspgn zanspgn is offline
Mein Auto: 2002 530i
I had the same problem with the brakes and engine on my car after a car wash once and after rain storms occasionally. I got code P1353 (Misfire Cylinder 6 With Fuel Cut-off). Turns out it's a clogged drain by the brake master cylinder. Remove the interior cabin filter on the driver side, unhook the vent tube, squeeze the clamp and lift up the plastic tray the air filter rests in. There you will find the brake fluid reservoir and master cylinder, and it will have water in the bottom if your drain is plugged. Use a straight coat hanger and clear the drain hole which is in the bottom of this area towards the middle of the car. After I did this I didn't have any more trouble. Wish I had known this before I had the coil and spark plug replaced on cylinder 6. The reason water causes these symptoms is that when you depress the brake pedal water gets into the brake booster and then gets sucked into the engine.
Old 10-30-2012, 09:46 PM
Alis_khan Alis_khan is offline
Mein Auto: BMW 528i
I had the same exact problem with my MW 528i. I spoke with several mechanics and everyone wanted me to bring it over to replace the vacume pump and the hoses. My point to them was why does it only and only do it on a rainy day.
After reading the threads here. I went ot my car and took off the air filter and its cover on the driver's side. That exposed a big pond of water right under the master cylender. The drainage was clogged. I took a hanger and put it thru the drainage hose and there was allot of water that got out. I put everything back and took it for a drive and that looks like fixed it.
Old 10-31-2012, 07:07 AM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
The clogged drains led to flooding in that compartment in your car. That water made it into your brake booster which is causing the brake problems and your misfire. Draining the compartment gave you temporary relief, but you need to replace the brake booster since you are in BC. You cannot got all the moisture out of the brake booster and it will freeze on you this winter rendering your brakes useless. I had this happen to me. My brake booster flooded in June and by that following January started freezing up. Over 8 months later and I still was able to extract significant amounts of water from it. Don't put your safety or anyone else's safety at risk, drain the compartment, clean the drains, and replace your brake booster.
I like coffee.
My e39 is fixed and moving towards atrophy.
Old 10-31-2012, 08:44 AM
Mein Auto: BMW 528i
Cloged Drain
So now I am scared. Are you surethat I have to replace the booster?
Also have naother issue that jsut came up yesterday. The car was loosing power and I thought that it was because of the drainage problem. I just found out that the head cylinder case on the top was over torqued and has a small crack in it right by the 3rd cylinder. Would this be enough for the car to loose the vacume power?
Thanks for all youe help.
Old 10-31-2012, 08:46 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
Clogge drains in the cabin filter over the brake booster. Get the water out or you will blow your engine. Do not drive it like that.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 11-01-2012, 02:00 PM
Originally Posted by Alis_khan View Post
So now I am scared. Are you surethat I have to replace the booster?...
http://www.bimmerfest.com/forums/sho...452&highlight=
The only way to fix it is to replace it. I have yet to replace mine, but I don't know if it will freeze yet. Last winter was so mild that it ended up being a non-issue except during January and February.
In regards to your other problem, cracks in the cylinder head are not good and can cause a variety of issues. The head is going to need to be replace which will be time consuming and expensive.
I like coffee.
Old 11-01-2012, 07:21 PM
Mein Auto: BMW 528i
So my question is that woudl the crack make any difference on the vacume of the car?
