X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
Can somebody HELP? Is it posible to run the existing x3 deck that plays mp3's and be able to install an 10 inch sub and JBL amp? I'm having trouble finding an answer to this without replacing the existing deck.
Is there is some sort of hubb you can buy?
Evlengr is the audio specialist in here, he should answer you pretty soon
Mtx
Thanks 06
You guys know me too well already.![]() Yup there are plenty of products that will do exactly what you are looking to do. And imo a 10" sub in a closed box firing toward the tailgate is sonically the best sounding in our vehicle. A closed box will give a nice clean kick of the bass drum and not that horrible whump whump whump you hear from kids cars (that is created by a ported box). I use Crutchfield as a link because they are good at breaking things down nicely (not because they are always the cheapest or best--however their CS is really good). http://www.crutchfield.com/p_236REQ5...Q5.html?tp=428 Can't claim credit for this recommendation as I use the Alpine version, but from what I can see it seems to be the simplest to use. The alpine takes some patience and an Alpine H/U. This works off factory H/U. There are two versions of this unit: $130 $180 I linked the more advanced.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
Hey Evlenger, any experience with the J & L Audio cleansweep? I just pulled that from my Saab and will be installing along with 4 channel Alpine amp, Rockford Fosgate mono amp for single J&L 10" in a box? Didn't mean to hi-jack the thread, you seem to be th expert here, thanks.
Thanks alot I hope the installation is not too hard. They are sure a pricey peace of art.
Evlenger you the man!! Thanks guys.!! Last edited by SCORPION_x3_05; 11-30-2009 at 07:20 PM. |
Don't know if I am the expert, but I sure do talk a lot
Looks pretty much straight forward on the JL cleansweep.
I take it you will need to know the speaker inputs, or outputs from the H/U, where to mount the bugger ?
I found a vacant compartment next to the battery for the cleansweep, amps will be mounted on the drivers side wall in that same general area. Now to find a spot for my satellite radio.....
get a soundgate locx. its a line output converter what it does is it uses a speaker level signnal by tapping into the speaker wires and changes it into a low level signal and gives you rcas no speaker will be sacrificed
Cheers, EE
Lot of Space
Here is what I am talking about as far as mounting additional equipment.
If you look very close you can see that I have circled the areas for removing the bolts for the panel (very carefully remove).
