what is a Lambda? - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 12-01-2009, 07:08 PM
timrobinson4206 timrobinson4206 is offline
Mein Auto: 1995 530i
what is a Lambda control 1?
i have a 95 530i. it started to run rough (shake at stop or low rpm on highway) and i got the code 1222 Lambda Control 1. i dont know what a lambda is? has anyone had this code? what was your fix?
Old 12-01-2009, 08:12 PM
nmp411 nmp411 is offline
Mein Auto: 90 535iM
Most likely your Oxygen sensor. That code can mean other things, but that is the most likely part.
Old 12-02-2009, 04:24 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Lambda... 1/3 of a Nerd fraternity
You can look up the codes on bmwe34.net but they do not get into the explination? I posted a link to it on this forum a couple of months ago. Here is another link that should be of more help, It is on the e30 but still should apply. This lists the Most common causes for code 1222.
http://www.verrill.com/car/idle/e30_idleproblem.shtml
Old 12-02-2009, 04:33 PM
ruf-porsche ruf-porsche is offline
Mein Auto: BMW, PORSCHE, LOTUS
[QUOTE=CarDriver;4730964]Lambda... 1/3 of a Nerd fraternity
Best Answer
Old 12-03-2009, 08:08 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
In an effort to collect more money from vehicle owners by boggling them, I believe the auto industry has substituted "lambda" for "oxygen" in describing the sensors... I guess it's working??
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 12-03-2009, 08:40 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Lambda = is an exhaust gas composition sensor to monitor chemical composition of exhaust gases especially NoX
(oxides of nitrogen )and feed data to the engine control system . Essentially , an oxygen sensor positioned in the exhaust pipe , so in all once the 02 sensor is replaced it should take care of your erratic idle problem .
Old 12-03-2009, 11:28 PM
Viktor Viktor is offline
iL Viktor
Mein Auto: 1999 Mazda B2500
For a second there I thought I read "La Bamba" ... interesting term, oxygen sounds easier to remember!
Old 12-05-2009, 10:09 AM
benchmark benchmark is offline
Mein Auto: BMW
Lambda is a value (1) which relates to your air/fuel ratio ie how rich (below 1) or how lean (above 1). The Oxygen (lambda) sensor installed in your cat analyses the ratios of your exhaust gasses and the ECU makes the necessary adjustments. The Lambda setting of any particular car is a compromise between power and fuel economy and the ideal value is taken to be 1 (14.7:1).
Old 12-06-2009, 04:36 AM
attack eagle attack eagle is offline
No more e34!
Mein Auto: Nikes + Mongoose
oxygen sensors don't read air fuel ratios...
they read lambda (stoich), so at when reading STOICH which is 9:1 for alky, and 14.7:1 for gasoline, your wideband sensor will read alcohol's stoich as 14.7 on the gauge.
From wiki
The sensor does not actually measure oxygen concentration, but rather the amount of oxygen needed to completely oxidize any remaining combustibles in the exhaust gas. Rich mixture causes an oxygen demand. This demand causes a voltage to build up, due to transportation of oxygen ions through the sensor layer. Lean mixture causes low voltage, since there is an oxygen excess.
Still cruising after all of these years...
now on iOS 9 (saves gas)
Mutual Admiration Society
Member #5
Old 12-06-2009, 05:01 AM
Mein Auto: BMW
How to split a hair!
http://www.dtmpower.com/Exhaust%20Ga...a%20Sensor.pdf
