Z3 Oxygen Sensors - Bimmerfest - BMW Forums
Old 12-07-2009, 05:18 PM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
Z3 Oxygen Sensors
Has anyone replaced the O2 sensors on their Z-3? I know there are front and rear sensors (2 for each side)...right? Looking at the diagram on RealOEM.com, they appear to be running off the headers /manifold. So, how do gain access to them so they can be replaced? Your response will be greatly appreciated.
Old 12-07-2009, 06:43 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
you just jack the car up on stands...slide under and remove the appropriate sensor.
FYI bank 1 is the 3 cyl to the front of the engine.
Some of them you can get to with a standard o2 socket, otherwise you need the appropriate flare wrench.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 12-07-2009, 06:47 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Purchase a BMW repair TIS disk.
Around $15 from EBAY,
Old 12-08-2009, 09:46 AM
Guess I'll be ordering the sensors today. Thanks to both of you for the advice/help. By the way, I have the ETK installed but am having some difficulty with the TIS, but am getting help from the forum member who originally emailed me the info. to download the program.
Old 12-21-2009, 10:17 AM
Thanks for everyone's input/advice. I replaced the 2 sensors on the top side of the engine using an O2 sensor socket...now the 2 sensors underneath the car...looks like fun!
Old 12-21-2009, 11:00 AM
Ron Stygar's Avatar
19,585 Miles
Why don't you just purchase it?
Old 12-24-2009, 09:25 AM
Thanks Ron...found one on Ebay...will be here soon!!
Old 12-24-2009, 09:41 AM
Ron Stygar's Avatar
19,585 Miles
You will get a later version and be ready for the Z4.
