The X5 SAV Forum
Old 12-09-2009, 02:33 PM
02BMW_X5 02BMW_X5 is offline
Mein Auto: BMW X5
Thermostat issue!!!
I believe that the thermostat on my 02 X5 is defective. The interior heat is not warm. I need some help to locate the thermostat so i can replace it. I'm from minnesota and it's 9 degrees today. LOL. Any help would be appreciated. PICTURES WOULD BE GREAT!
Old 12-11-2009, 01:10 PM
Scott ZHP's Avatar
We want the Lion!
3.0 or 4.4??
Old 12-11-2009, 01:30 PM
seeskan seeskan is offline
Mein Auto: 05 X5 4.4/05 330CIC
Does your coolant tempeture guage reach to "normal" about middle of the dail after warm up and stay there? If yes ,then the themostat is good
Old 12-11-2009, 05:08 PM
Red Coat Red Coat is offline
Mein Auto: see "my garage"....
Thermostat
Follow the main radiator hose from the top right (as you're looking at the engne) around to the aluminum housing. The thermostat is inside. Bavauto has them for $75.
If you're a first time X5 (or Bimmer of any kind) owner then I'll pass on this lttle tidbit for you about your X5 and the balmy winters you have like we do here in Canada.
Purchase a pan heater and ensure your vehicle is plugged in when it gets cold. Don't listen to those who tell you they don't need to be plugged in. There are no block heaters on any of them and they really shoudn't need one, but because it gets so cold where you are, the oil separator at the bac of the block can hold condensation if your drives are short. These freeze ups can cause catastophic engine failure. Ensurng the oil is warmed helps but will not completely solve the probelm. BMW claims to have a "fix" and they may well have, but I'm told it's not a guarentee. BMW aso refuses to truly acknowledge the issue (from the ast I heard) as this part of the world is about 1% of sales worldwide.
I put a pan heater on mine last year. So far so good.
Love them and would have no other, but they do have their issues...
RedCoat
