E46 (1999 - 2006)
Old 12-26-2009, 06:06 PM
phil0618 phil0618 is offline
Mein Auto: BMW 528i
Which auto transmission to I have (ZF vs GM)?
Hi,
I've been all over the forums looking at various items related to changing transmission fluids.
I just want to confirm the transmission on my car without having to jack up the car.
My car is a 2003 e46
The plate on the door says 06/03 (June, 2003)
The last part of the VIN reads KP81689
The sticker on the underside of the pan is green, but I can't read the markings
(i can see the sticker is green by placing a mirror under the car)
It's a California car and so I believe that I have the M56 SULEV engine (oil fill in front of engine)
The e46 wiki states that as of March 2003 all transmissions are GM.
However, I also used a VIN decoder I found online and it said that I had the ZF transmission.
Is it possible to know for sure just using the above data which transmission I have?
Best,
Phil
Old 12-26-2009, 07:58 PM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
It's a GM, you have a 2003 and 1/2 model like I used to and its sort of got a weird mixture of stuff. I did the same thing you did and bought the filter for a ZF transmission, didn't figure out it was a GM until the tranny was drained. Turned out to be quite a long afternoon chasing down the right filter.
EDIT: I'm pretty sure I edited the wiki when i figured that out.
Old 12-26-2009, 08:26 PM
Melquin Melquin is offline
Mein Auto: 2005 330i
AFIK all the M56 vehicles had the ZF transmissions. (see attached PDF). I have seen some of the ZF blue stickers that have oxidized and turned sort of a bright metallic green color over time. (as opposed to the more flat-puke green colored GM sticker). Best to check the recommended fluid part number listed on the label to verify which you have.
edit: PDF was too large so just took a snapshot of the first page
Old 12-26-2009, 09:08 PM
SlimKlim's Avatar
Speed is Zen
Originally Posted by Melquin View Post
AFIK all the M56 vehicles had the ZF transmissions. (see attached PDF). I have seen some of the ZF blue stickers that have oxidized and turned sort of a bright metallic green color over time. (as opposed to the more flat-puke green colored GM sticker). Best to check the recommended fluid part number to verify which you have.
Ohh, didnt know that, sorry about the misinformation. I wonder why they would bother to fit two different trannies for the different emission engines.
Old 12-26-2009, 09:43 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
I just decoded your VIN. Your tranny is A5S325Z which is ZF tranny. It requires ESSO ATF LT 71141 fluid.
Old 12-27-2009, 06:12 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Count the pan bolts. The GM trannies have 22 bolts, the ZF have 14.
Old 12-06-2012, 10:21 PM
STREETFIGHTER50 STREETFIGHTER50 is offline
Mein Auto: '04 ZHP Silver-Grey 6sp
I'm just peeking under the car & can't really see or read anything off of the sticker. I'd have to lift it up this weekend to tell I guess. My car's VIN # tag reads 08/03. So is it the GM tranny for sure?
Old 12-07-2012, 01:45 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Read Smolck`s Post# 6....it doesn`t get much more definitive than THAT !
The road goes ever onward....
(R.I.P. Jever)
Old 03-28-2016, 11:54 AM
elbert's Avatar
elbert elbert is offline
Sikkens Autocryl MM
Mein Auto: Ford Tempo GL
Came across this thread on Google, so I'm bumping it up from the dead because...
The ZF has 22 bolts, while the GM has 20. Granted the GM gasket has 22 holes, but only 20 bolts.
But otherwise great idea, better than using label colors like that idiotic Bentley manual suggests.
I believe the pans are shaped a little differently too. The ZF's is more-or-less trapezoidal. The GM's is an ovalized rectangle, but it's symmetric.
Old 10-03-2016, 06:41 AM
moapys moapys is online now
Mein Auto: E30 325is cabrio; E90 'xi
I have the "slow to engage" issue on my (2003) 330i, so embarked on the filter/fluid adventure: I just got this one (my fifth of several E46)...but this is my first with a GM auto tranny. My confusion is that all forum/blog threads seem to suggest that ONLY the 330ix (mine's just an "i" rwd not awd) has the GM transmission . It has the 20 bolt pan/gasket, and is wearing the green GM-France tag. Seemingly it has to be a A5S390R, but that never comes up for ordering for this VIN, model, age, etc. 'Sure makes getting filter kits a challenge
Does anyone else have the '03-330i (sport pkg) with the GM green label? I guess I'm wondering if it got a donor AT-gearbox from a 325i, which did appear to be outfitted with the French-GM... - - THX!
Old 10-04-2016, 06:15 AM
marcozandrini marcozandrini is offline
Mein Auto:
Check the fluid pan. If the pan's bottom is smooth the tranny is a GM. Otherwise it's a ZF tranny. Yes, they require different fluids and filters.
