Discussion pertaining to the flagship BMW here. |
760li reset oil service light
I have a 760LI. I have gone out of the warrenty from the stealer and have finally had to do my first oil change.
I looked all over for the solution to this quandry and have found it different for my car by one small step from everyones stated resolution on the 750LI. You have to have the car running to reset the oil light. On my car if you do not have the engine running the menu is completely different and you cannot get to the reset area!! I have copied the details from the web on how to reset below. . 1=Sit in the drivers seat,doors shut and key out of slot. 2=Put key into slot and press the start button so the ignition is on.(not started) 3=Wait 5-7 seconds,then press and hold the button in the cluster top of speedo dial. 4=Hold this button for 5-7 seconds and a menu should come up in the middle of the speedo dial when this happens let go of the button and then to scroll through the menu use the same button in the speedo dial until you come to the oil millage. 5=Then press and hold the same button again for 5-7 seconds and the next menu should come up in the rev counter dial,scroll through this menu to reset and press and hold for the last time. This should reset your millage for the oil. Again, this may be unique to my car based on the settings loaded by the dealer, but it frustrated me over 5 days looking for a 760LI reset procedure. Hopefully it will help you! |
Thank you so much !!! I tried this not knowing if It would work but tried it anyway..... It took me about 20 seconds and I was done !!! Wow.... The dam dealer was trying to charge me a atm and leg,he even said I needed special tools and that he use to work at BMW ,and If I didnt do it right I would fry the harness .... What a @#&$ !! Thanks again ....
Red car still on?
OK, so my red car has been on for a few months telling me I needed to change my rear brake pads & when I finally took my car in to my favorite mechanic (my son) the I-Drive said -8000. I also had my oil changed even though the I-Drive said I did not need one for another 12,000 kilometers. He did both jobs for me & said everything went smooth & home I went. Once I got home I came on this forum to get the instructions on resetting the service warnings. I reset the oil & it displayed OK & the new number was 24,000 kilometers until next service. I then changed the rear brake service warning & it also read OK. I got in the car this-morning & noticed the red car light was still on so I checked the I-Drive & now it reads -16,000 for the rear brakes? Any ideas on where I went wrong & how to correct it? TIA
Perfect bro worked easy
Ok, Im stuck on stupid but what is the "cluster on the speedo dial"? I have a 2006 so I just have the circular turning knob in the middle of the arm rest. Not sure what is a speedo dial and surely dont know what cluster youre talking about. LOL.
Number (1) in the attachment is the button you use.
Thanks a lot. Ill try this when I get home.
