1997 528i OBD port location
Hi Everyone, I'm the new owner of a 528i, and I just cant seem to find the obd port anypalce.
I've tried the left side below the steering wheel all help is appreciated Thnks! Raul |
isnt it right below the steering wheel where you just mentioned?
bottom left. look up and deep
when in doubt, use the pac man
americandan.com
![]() ![]() ![]() It takes a lot of work to be lazy. |
you already found it but there is another cover on the plug beneath the cover you see from the outside.(ie there are 2 covers a cosmetic one and another one below it)
>'97 528i, 175400 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'87 528e, 210000 miles, mice, mouse nests, mouse pee smell, style 31s >'65 & '74 MG Midgets BFC OT Lego Club #48 |
I, have checks what you guy told me and still no luck, I'll pot pics tomorrow with better light, but as far as i see...
I have some kind of small box attached with 2 screws, removed them already and found nothing (maybe its here but I didnt look for that "other" cover as for going low and deep I have a big black plastic cover with a whole lot more screws in (i really believe its not here.)i'll cehck on tomorrow and if i have trouble with it i'l snap a pic Thnks Raul |
I thought only 2001+ had the OBD-2 port to the left of the steering wheel.
From 1987-2000 is the round port under the hood. |
Mine has one, I was staring at it last night and I have plugged my scanner into it a couple of times now.
The non-US model has different dash padding...the port might be in a different place in the OP's car.
1984 318i/man./Tornadorot* 1990 525i/man./Alpinweiß* 2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige* 2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige* 2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau* 2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige* 2012 VW Golf R/Rising Blue *retired |
I have the same issue with this thing.. my car is a 528i 1997 made in 96
went i got this car one day a Sir scan my car in the OBD port above the steering wheel (The normal one) it passed a year and my check engine light appear and i want to scan to see what it is.. The problem is there is no damn plug inside the port or nothing similar to plug in with an normal autozone scaanner ... and it use to be one.. What can i Do to reset my Codes? and elminate the check engine light or faulty codes?.. What other opcion do i have? Do they sell the Plug that goes inside ? |
There's always the round 20 pin DLC connector in the engine bay.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
The DLC under the dash is the one that BMW uses, up to 2001, however, all cars destined for the USA (and other parts of the world, too, depending on adoption of OBD) require the OBD II port under the dash. It's there!
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
