Old 01-03-2010, 05:01 PM
rchinn rchinn is offline
Mein Auto: E39 540i 2002
replaced water pump - now coolant leak under shifter
Long time lurker - first time poster!
My 2002, 540i 6speed has 99,984 miles (almost made it to 100,000). Yesterday my water pump bearing exploded and the serpentine belt disintegrated.
I put in a new h20 pump and belt. Everything is fine. Well almost....
When I turn on my heater (I get hot air), I see two puddles under my car. The drips come about every 3-5 seconds. When I have the A/C on cold no drips.
HELP!
Thanks,
Randy
Old 01-03-2010, 05:22 PM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
It might be the heater hoses behind the intake manifold. If you haven't replaced those, they are cheap. The coolant is probably leaking onto the tranny then making its way down.
Old 01-03-2010, 05:30 PM
Maybe I damaged or dislodged them when removing the water pump? There are two going into the pump (input/output?). Perhaps when I pushed and pulled to get the metal pipes out of the pump, they were dislodged in the back where they connect to the hoses in some way?
Thanks again
Old 01-03-2010, 06:41 PM
02540ico 02540ico is offline
Mein Auto: 1997 850Ci
Most likely the o-rings for the 2 pipes that run under the intake to the rear water manifold. Did the pipes come out when changing the pump? If they don't go back in very straight, the pipe can tear the o-ring.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=163865&dateline=1256592405
Old 01-04-2010, 10:03 AM
Does that mean I have to remove the manifold to get to those O rings (e.g., several hour job)?
Thanks,
Randy
Old 01-04-2010, 01:28 PM
Where are the puddles? Back of engine, side, front?
If it is the transfer pipes, I believe the intake plenum has to be removed to access the o-rings, also either the water pump, or rear water manifold.
Try to find the source of the leak before spending hours and $$ replacing parts.
Old 01-04-2010, 03:57 PM
The puddles are underneath the back of the engine. I'm just a weekend do-it-yourselfer so I may have this wrong, but it looks like my tubular frame joins in a "Y" under my manual shifter. The water drops on two sides of the singular portion of the "Y"
Randy
Old 01-04-2010, 04:34 PM
Pop off the engine cover so you can get a better view of the back of the engine. You should be able to see if it's a heater hose, the valley pan, or the tube(s) from the water pump. You may have to use a mirror to see everything.
If you're only seeing the leak when the heater is on, I'd have to agree with SoCaLE39 on the heater hoses.
Old 01-05-2010, 12:24 PM
Interestingly, my leaks have stopped! (Yes I still have coolant Can't explain it, with the heater on full blast everything is dry as a bone and I didn't change a thing.
I was able to see the heater hoses by taking off the engine cover and using a mirror. They are all dry with everything running.
Maybe bleeding the system helped? Anyway, for now, I think I am good. Thanks to all on the forum for the help.
Randy
coolant leak, heater problem, water pump
