523i very hard to start
I have a 1997 523i which is very hard to start mostly when cold, if i keep cranking for 10 mins or so it will start and run perfect, any suggestions ?![]()
Might try the temp sensor thats located on the engine head, that sensor gives the computer the info when to richen up the mixture and go lean when first cranking the car.
I would check this and the battery as well......
hello, had exactly the same problem. in the end after trying everything took it to bmw and they did a software reset on the car, that cleared the starting problem. it cost me £140.00
Thanks for comments
which one there are 2 sensors under the manifold.
The sensor at the back of the engine is the one that the computer reads from. That one doesn't have any wires going to it you stated? If it isn't hooked up that would be a big reason it doesn't crank when cold.
