Old 01-15-2010, 01:21 PM
grollins001 grollins001 is offline
Mein Auto: 2000 BMW M Roadster
M Roadster Oil Separator Replacement
I've got a 2000 M Roadster (Z3 E36 - S52 3.2l Engine) and want to change the Crankcase Ventilation/Oil Separator Valve (OSV) and related hoses/tubes, and am looking for helpful hints/instructions. The Bentley manual, of course, is devoid of such info.
I've searched this and other sites and have found DIY instructions and helpful hints on doing the OSV R&R for other models (particularly E46), but my limited searching skills have not enabled me to find anything specific to my model.
Has anyone changed the Oil Separator Valve on an S52 M Roadster? If so, is there anything peculiar or different about doing it on this model as opposed to the instructions/helpful hints for other models?
If there are forum posts or other sites that contain OSV R&R info for this specific model, could you please point me in that direction?
Thanks much for any helpful replies.
Old 01-15-2010, 02:06 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Purchase a BMW TIS repair disc from EBAY.
Old 01-15-2010, 04:22 PM
Vinci Vinci is offline
DO IT YOURSELF.
Mein Auto: 98 M Roadster
This may be covered in the Bently manual as well. I did this once as part of an operation to replace an intake manifold on an S52. As I recall, it's not terribly difficult to get to, once you take off the air intake equipment (air box, hoses, throttlebodies, etc.). The oil separator is an odd-looking, black, plastic device located under the intake manifold, towards the rear of the motor.
Be sure to label all the vacuum hoses that you remove. There are several in that area, and they all start to look the same after a while in that area.
Old 01-16-2010, 01:24 AM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
Have you seen this write-up for an E36 M3 S52?
http://m3forum.net/m3forum/showthread.php?t=263731
