E36 (1991 - 1999)
#26
See explanation above. It's a simplified approach.
![]() Quote:
![]() Quote:
I should note that since both LL-98 and LL-01 had not been developed until the E36 was nearly phased out, it would be absurd to say that LL-spec oil is necessary for our cars. Would you not agree?Quote:
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
#27
All the BMW meistermechanics I knew in Germany swore by Castrol oils.
#28
very much needed thread thanks alot man
#29
Call me crazy, but I just put in WallMart Super Tech 5w-30 synthetic in my 94 325i with 63,000 on the clock. just bought it when it had 61,000 and don't know what oil was used but seems it was always serviced at a BMW dealer. Have used Super tech oils for some time, in hard driven snowmobiles and a WRX Suberu etc. with very good results. These oils meet the highest BIA (for 2 cycle oils) and API SF rating etc. SINCE BMW now says 5w-30 is good, why not ? Actually Super Tech is from Penzoil, maybe not a Mobil one , but not an off brand either. The Subie engine with turbo and 230 hp is certainly higher stressed than the BMW naturally asperated 6 so I can't believe there will be a problem. If so will let you know, if not will spend the substaintial savings on other fun goodies !
Cheap Trick |
#30
I've been using Walmart brand oil in my Dodge 1500 conversion van, Nissan sentra, and my 328I and have concluded over the years all you need to do is have a regular schedule oil change.
#31
This is a great write up thanks for the info!!!
#32
I have done extensive research on oils, and I used to race motocross with my sons that were sponsered by Richmond Kawasaki in the early 90's.
I always believed in regular oil changes in the cars and trucks I have owned. But let me tell you a story. We were racing in the Golden State Nationals and I was talking to another parent that was working for Neo Oil in L.A. They were running a couple of Pro bikes (they were two stroke motors back then that turned 12-14,000 rpm) on their Neo synthetic oil using a mixing ratio of 100 to one. Normally, I was using 32 to one. They had no siezure problems and ran 100 to one ratio just to prove how much better their oil was than the regular racing oils. I had a KX-125 my oldest son was racing that had seized that day, and we realized the jetting was too lean for Glen Helen, CA . I switched pistons, put in a 40 to one mix and raced the rest of the year without seizing the motor. Never changed the jetting either. Then I changed all my vehicles over to synthetic. I buy whatever is on sale for my four wheel vehicles as long as it is full synthetic. I'm using Royal Purple right now because it was on sale at Kragen A/P last year. BMW recommends Castrol synthetic. It's stamped into the radiator cover on my '03 325ci. I still say changing your oil is more important on cars than what type of oil you use, unless you are like me and insist on full synthetic now. I am now wondering why my '03 325 oil change warning light is every 15,000 miles. Seems too long for me, so I do it every 10,000. So far. |
#33
Sorry to tell you.. Royal Purple is not a true full synthetic.
#34
Im using Castrol EDGE and its pretty good. Im using 10W30, next oil change will prolly be 10W40 or somewhere around there
-Usama ![]() "The American Dream only makes sense if you're sleeping" - Lowkey |
#35
It's a Group IV, that puts it in the true synthetic category, along with Mobil1 and some of the Castrols, and that's about it.
#36
Or so it is labelled... Upon further research I found there really is no true full synthetic.
#37
Anyone here ever seen this?
http://www.ferrarichat.com/forum/faq...=haas_articles Based on this I'm switching to 0w30. Any thoughts? Last edited by advertisehere; 01-17-2010 at 01:54 PM. |
#38
I've read it, and it's an excellent article. Running a 0-weight is fine for cold conditions, but you have a problem when your car gets to operating temperature if you're running 30 weight, that's far too thin. That article is based off Ferrari's specs. 30 weight on a daily driven 575 Maranello might be great, but 0-30 IS too thin for the M50/52 engine. The 0 isn't the problem, the 30 is. He's comparing differences between 0-30 and 10-30. If we were talking about 15-50 or 20-50 compared to 0-50, sure, you can run the 0-50 just fine. But no, 0-30 is not an acceptable oil for an M50/52 engine'd E36.
#39
One thing I'm not clear about***********: under normal operating conditions and at operating temperature, the oil temp should be the same regardless of the ambient temperature (if it does, the cooling system is at fault). So what's the difference between a 30-weight at 10 and 100 degrees Fahrenheit?
also, isn't 0w-X inherently better in any climate than 10w-X because of the reduction in thickness at sub-operating temps btw, I don't know what those asterisks are doing there Last edited by advertisehere; 01-17-2010 at 04:13 PM. |
#40
This board puts asterisks in retarted places sometimes. It doesn't like ellipses and colons, dunno why.
![]() I agree that the oil temperature should be fairly constant regarding ambient temperature, however, BMW and many other makes specify various grades for various ambient temperatures. I tend to follow the line of reasoning that they wouldn't have gone to the work of determining the best grade and wasting a full 2 pages in the manual spelling it out if there weren't some reason, even if it's not readily apparent to us. As for 0-X vs 10-X, if the X's are kept constant (ie, 0-30 vs 10-30), yes, theoretically the 0 should be the preferable one. If you're going with 0-30 vs 15-50, then no, just because it starts with 0 doesn't make it the better choice.
#41
Okay, well I'm going to ask BMW and see what their reasons are.
I'll post up the reply if it's of any substance. |
#42
By BMW, do you mean emailing BMWNA or asking a local dealer? If it's BMWNA I'd be very interested. If it's the local dealer, trust me when I say that they don't know crap.
#43
+1
#45
I got this:
Maybe ill try bobistheoilguy. EDIT: Oh, and the only thing they said on the phone is that thinner oil can increase oil consumption, which is more of a bandaid than a fix. Last edited by advertisehere; 01-22-2010 at 03:00 PM. |
#46
You would think that the information that they have available at BMWNA would be better. I mean they have to be paying those people decent money, but all the do is refer to the database?
#47
QW, the database is almost assuredly info BMW developed, but the reps appear to be too lazy to look it up.
![]() Sorry about the dead end with BMW, Terry. I'll try asking my mechanic on Monday if he has any info on why that may be. They do BMW/Mercedes only.
#48
eh, she seemed to be looking for a while. besides, i dont imagine stuff as technical as the question I asked would be a common question, so I'm not that surprised. Although i did think they might have a tech expert somewhere in the States.
#49
I figure that going with one of the oils which has the longest history of research and development makes a lot of sense; I have used Amsoil and Mobil 1 since 1977 with no problems. Personally, having done a lot of research, my preference is for Amsoil, Mobil 1 and Redline...but Mobil 1 is the least expensive and most readily available, since it is carried by mass marketers like Wally World. I have dissected a number of filters and examined them, and as a result consider Amsoil filters to be the very best, but that's another argument. I don't understand why people are confused about what weight oil to run. RTFM...or just check the chart that was so kindly included in the original post in this thread. That is really all you need to know. People obsess over motor oil MUCH too much. It's just oil, and all major brand modern motor oils are excellent. Use synthetic, keep it clean, change it at appropriate intervals and don't worry about it.
1983 Datsun 280ZX Turbo 2009 BMW 328iX Coupe 2007 Nissan Murano Last edited by Pilgrim; 01-24-2010 at 01:47 PM. |
#50
I emailed bimmerworld:
I then asked about a 0w30 and he said that would be reasonable, although there might be some sacrifice in protection under high load (I think that might have to do with oil pressure at high engine speeds but I didn't ask.). And since the vast majority of my driving occurs in trips that last less than 30 minutes, I think the 0w30 will probably be my best choice in the future. He also mentioned dealers putting in 5w30 for cars where the recommendation calls for a 40 with no problems arising. (not exactly in those words) I have a couple more questions though, so I'll probably call again tomorrow. And here's the product info sheet: http://www.redlineoil.com/content/fi...uct%20Data.pdf Last edited by advertisehere; 01-25-2010 at 05:46 PM. |
| Tags |
| filter, oil, royal purple, viscosity, weight |
