Old 01-20-2010, 07:19 AM
kimln1 kimln1 is offline
Mein Auto: BMW Z3
Z3 Roof leaking
In the recent bad weather Rain and snow before and after xmas I got into my car ) not driven for ages and the interior was soaked and water literaly dripping off the roof . It is all so wet and damp I bought a cover to cover it up from the weather , but have looked in again today and now the child seat has mildew on it , it's so damp. Surely this is not right. How much is it to repair / replace or is there some sort of Industrial waterproof spray ???!!! Can anyone advice. Thank you
Z3 s reg
Thanks Kim :cry
Old 01-20-2010, 07:40 AM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
products like Raggtopp can re-seal the top - otherwise you can go OEM or aftermarket for a new top.
OEM is more expensive but easier to fit. Aftermarket requires more work to fit and may not have removeable window.
Are you sure the roof is leaking throught the material and not at the door seals?
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 01-20-2010, 08:25 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I would do the ragg top treatment for good measure, but I doubt thats the issue.
The plugs on the A-Pillars are generally the culprit.
I used a little gorilla glue on them. Just a little bit around the edge of the plug, stuck the nib of the glue into the crease and gently squeezed. It expands a bit or whatever and sealed it right up.
No more leaks in my car!
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
