7 Series / 8 Series
The BMW 7 series and 8 Series Forum |
I really need your help if you know the answer.. Ive got a E38 735i on a 98 plate and the heater fan is not working. Now i dont know but is there 2 fans (Driver/Passenger) or just the one ? I think ive checked the right fuses but not 100%.. Is this a common problem or just me ? Where are the fans located or the relays ? I would be very happy if i can get this fixed as the winscreen and all the windows keep misting up :o(
Many thanks Jason..... |
Bump!
If you post in the correct forum you might have better luck.
******** DIY Board - POST DIY WRITE-UPS HERE, **NOT** TECHNICAL/OTHER QUESTIONS.
M.Wong E38 2000 740iL Orient Blue E91 2012 328xiT Alpine White Passed on to new families: E30 1987 325i Royal Blue E39 2003 540i/6 Sterling Gray R56 2010 Mini Cooper S British Racing Green
If I am understanding correctly... you are not getting any air/heat blown into the cabin of the car with the system turned on. If this is the case...It could be a bed blower motor or resistor that attached to the blower motor. Located underneath the dash board (upper half)
See the link below for info. visit partsgeek.comfor the part. Its where I got mine from http://www.bimmerboard.com/forums/posts/45351 |
I am sorry to hear that, but I would bet that your poor blower motor is worn out. I had the same problem on my car.. Try to give the dashboard a beating with your hand while having the air on full, to see if it starts turning. If it does, the motor is busted.
It is a pretty hard job to replace the fan, but i assure you, it looks alot worse than it really is.. You need to remove the entire top portion of your dashboard to access the fan. I did it in five hours just to give you an estimate on it. There are some good diy online about it. So check e38.org. Nothing else to do than to just start the job.. I am 100% sure that is the problem. Go to www.bavauto.com and order up the fan, and start working ASAP..
I did the same job (replacing the blower motor). It took me about 2.5 hours. I also work on jets so that speaks on behalf of my mechanical skill. But regardless, you can do it and save yourself some money. No serious tools required!!!
