Old 01-23-2010, 12:29 AM
Where exactly do we look on the E39 radiator for telltale cracks?
Searching, I find pictures of fingers pointing to hoses and photos of replacement alloy radiators designed to not have the fatigue cracks ... but WHERE exactly do I look for these telltale cracks in the 2002 525i automatic?
Apparently, when I do replace the radiator, other things will fail too (like the water pump). Is this the canonical cooling-system overall DIY (from cn90) for the 2002 525i?
Old 01-23-2010, 02:15 AM
Neversaynever Neversaynever is offline
Mein Auto: 2002 525i
On my '02 525, the slow leak was coming from the driver's side of the radiator. Many posts say look at the top of the radiator on the driver's side where the overflow/recirculate hose connects. This area often cracks. Your picture above in the center is exactly the weak area. In my case, all was dry and uncracked at the circulator hose and at the main coolant hose connection. I just had a slow drip coming down the driver's side of the radiator and onto the splash pan underneath. I believe my radiator was simply failing on the side seam after 135k miles and 7 years. The replacement of the radiator, water pump, and hoses was not hard.
CL
2002 525i 164k
1988 911 Cabrio
1986 911 Coupe (track car)
Greater Boston, MA
Old 01-23-2010, 10:05 PM
dcotti dcotti is offline
Mein Auto: 2003 525i Sport
Here's where mine went. As the previous poster said, its where the upper hose meets the plastic radiator housing.
Old 01-24-2010, 06:35 AM
1bad540's Avatar
1bad540 1bad540 is online now
Mein Auto: E65 750i Sport,C5 z51 e46
^^^^^ yup check where ever there is a hose connection into the radiator.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 01-24-2010, 07:55 AM
occhis occhis is offline
Mein Auto: 1998 528iA
When I loosened the clamp on the upper rad hose and pulled the hose off, the plastic neck came with it. About 1/4 inch remained with the radiator. Plastic thermostat housing also cracked.
Either you are part of the solution, or you are part of the problem.
Old 01-24-2010, 08:41 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Mine's leaking right there. This plastic nipple looks like it's clipped/snap fitted into the top of the radiator. Is this part replaceable? Or is a new radiator the only way that comes with a new nipple?
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-24-2010, 09:01 AM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Best place to look is your odometer. If it's over 80k then you're on borrowed time. LOL all seriousness aside Bluebee I went to 120k before I did my cooling overhaul with no issues. My thermostat did go bad at about 85k miles though and I replaced it quickly. How many miles you got on her?
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 01-24-2010, 04:50 PM
Bren517's Avatar
Bren517 Bren517 is offline
Mein Auto: 03 525i
and here i was thinking that I was close to being done with all my repairs mine is starting to show similar wear..
The other day mine decided to spit coolant all over that side of the engine bay..
03 525i - e60 M5 18" wheels | M5 front grill | HIDS | Front Strut | Koni adjustables with Eibach springs
Modified stock intake / CF Heat Shield | AUX IN | Focal coax | Focal power sub | Tinted Windows
Old 01-24-2010, 05:07 PM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
I'm at 62k and had a leak right around the water pump, so I replaced that and the thermostat preventively. I went over the radiator carefully and did not see signs of leaking, but I did replace the upper hose cause it was brittle though not leaking. But I'm planning on/assuming I'll have to replace the rad w/i a year. or around 70k miles. Not sure which rad I'll put in, but it won't be OEM.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 01-25-2010, 06:08 AM
cn90 cn90 is offline
1+!!!
Bluebee, the classic crack is exactly where the UPPER Hose joins the radiator.
This is the area where the plastic neck (the hose attaches here) joins the plastic side tank.
The problem is: it may leak slowly, giving you time to fix, or it can erupt like a volcano with no warning.
Some people have crack radiator at 60K, some runs all the way up to 160K or so.
I am like Mack, stay on the conservatibve side, and replace the rad at 80-100K, considering that an overheated engine will cost you some $4-5K bones!
Old 01-25-2010, 06:48 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
I was saying the same for the longest. But an OEM rad only cost me $146 to the door. A Zionsville would've cost around $600. I did the math, it didn't work. I went with OEM/Behr.
1+!!!
Agree whole heartedly bro. Plus I didn't want to end up stranded out somewhere and have to shell out mad ca$h to get it fixed on the road if I was too far away from home.
Old 01-25-2010, 08:11 AM
83916 miles.
Thanks for letting me know where the "classic" break is; I will check where the rubber meets the plastic and write back what I find.
I know it will eventually need replacing (based on this thread and others); however, like others, I also must wonder if the obviously better 600-dollar all-metal radiator is worth it to replace the cheaper plastic radiator (depends on their respective "true" costs).
Not knowing which way I'll go, certainly I would feel safer with the aluminum radiator but we'll have to see if we can find a better price comparison to the OEM or OE (I haven't done that yet as I'm just trying to figure out WHERE to look first to see IF I already have a problem).
PS: I don't need more problems right now, trust me.
Old 01-25-2010, 08:21 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Hmm, I could have sworn I started a thread a year or so back to ask at what mileage all E39 owners experienced cooling failure or replaced proactively before failure. I can't seem to locate it though. Still, I think many will agree that if you're above 80k on your original radiator, expansion tank etc. it's time for an overhaul. I suspicion 525's are not nearly as hard on the cooling systems as the others because I made it to 120k with no major failures and confirmed I still had the stock rad but at that point I was getting nervous and decided to go ahead and put in all new hoses, expansion tank, rad and water pump because I didn't want to end up stranded somewhere. Anyways goodluck with what you decide!
Old 01-25-2010, 08:34 AM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
I don't think radiator failure can be related to a specific mileage. It seems to be caused by repeated heat cycles. After many, many times of the plastic being heated and cooled and flexing with internal pressure, it will become brittle and crack. Bad motor mounts will exacerbate the flexing. The additional heat of a V8 will cause it to happen a bit earlier. Cracks are common at the upper and lower hose connections, but can occur anywhere on the plastic, including the side seams. The expansion tank, thermostat housing, and all other plastic cooling system parts may also be the source of failures. Many, if not most, cooling system failures are catastrophic, requiring the vehicle to be immediately shut down and towed for repair. Failure to do so can result in significant engine damage, particularly in the I6 cars. Far too often the first sign of a crack is complete failure.
Considering the risk, most here think it prudent to refurbish the cooling system at 60-80k miles, although my radiator failed at about 50k. Desert heats and a V8 engine appear to speed the process. I am now considering Evans NPG+ in a zero pressure system. It is a lot cheaper than a Zionville radiator.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 01-25-2010, 08:39 AM
Josh P.'s Avatar
Bimmerholic
I'd also add that many if not most of us do the majority of our driving in the nicer/warmer months, so more o' dem miles are coming when the temps are higher, putting more stress on the rad. All you daily drivers need only worry about the CCV freezing and cracking! Haw haw haw!
Old 01-25-2010, 08:44 AM
I'm above 80K so I'm worried but I'm still a bit confused. Did I mark the right spot below on the composite diagram where to look for the classic crack?
(If not, I supplied a blank composite for someone to correct where I err.)
ID:	216107   Click image for larger version
Old 01-25-2010, 09:36 AM
It is the port on the driver's side which you note as the "classic spot". Except most people have trouble with the circulation connection which you can see pointing across the top of the radiator.
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
Old 01-25-2010, 09:41 AM
Pic attached. For what it's worth, just replace the radiator and call it a day. Don;t worry about hoses or anything else. Not a bad job if you've had the fan off previously.
And BTW, how do you post a picture full size? I only know how to post the thumbnail.
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
Old 01-25-2010, 03:22 PM
BadBrad BadBrad is offline
BadBrad
Mein Auto: 2003 540iA M-Sport
Mine split just below the upper hose connection nipple on the plastic end cap at a spot close to where Bluebee pointed to in the diagram. It happened on the way home after picking it up from the dealer. Luckily I was near an exit on interstate 95 and was able to get it off at the exit and shut down. It had 76K on it when I took delivery. One thing compounded the problem, the pixels on the cluster were so bad that I couldn't read the warning of low coolant. When the high temp alarm came in I could just barely make out the "TEMP" part and only then knew exactly what was happening. Luckily I was within 500 ft. of the upcoming exit and could get off and shut down quickly before any serious damage happened. The dealer towed and replaced the radiator as MA has a mandatory 3 mos/3.6k warranty for all used vehicles under 90k total miles. BTW, I've since had the cluster replaced under the BMWUSA goodwill program.
Old 01-25-2010, 04:15 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Bluebee, the radiator is sometimes but not always the first thing to go. My grandfather had a hose blow up, followed 2 weeks later by his expansion tank spontaneously blowing out. I've had a leaky... something... under my expansion tank that leaks when it's <0C, but it's been that way for 10k km. (fingers crossed) The weather sucks, so I'm waiting until later this year (if I'm still driving it) but I will be doing the whole cooling system. No f*cking around is what I've learned (so I'm f*cking around pushing my luck to 100k miles)
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 01-25-2010, 04:22 PM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
I totally disagree with this. IMHO you'd be crazy to change the rad and not do the hoses. No offense but that's what I'd call a half-assed job.
I'll have to defer to others here who have experienced rad failures but from what I recall many have experienced cracks right at the neck there. Some even after changing busted hoses just from the jockeying off and on with the new ones there at the neck after it has become brittle but again this is only what I've seen hearsay as I replaced all my stuff proactively not wanting to experience the nightmares that many here have seen. As always enjoy your thoroughness and goodluck Bluebee!
Old 01-25-2010, 04:49 PM
mnepitjr's Avatar
mnepitjr mnepitjr is offline
Mein Auto: 2002 525 2000 M5
I have to agree with everyone else. Mine went at 80k exactly. But started with the overflow tank, then thermostat with housing and finally the radiator blew at the upper hose connection. I replaced all hoses and pump since everything else was new. Like previous posters said, you're on borrowed time now.
Old 01-25-2010, 06:36 PM
Mine lasted till about 128K, but would not recommend waiting that long. Replace all parts as outlined by cn90 here: http://www.bimmerboard.com/forums/posts/199986
Old 01-25-2010, 07:59 PM
Pic attached.And BTW, how do you post a picture full size?
From what I can summarize, the cooling system can fail anywhere, but, the most common or canonical crack appears to be (from this thread) in both the large and small plastic "necks" as shown in the photo below (is this correct)?
PS: To post the photo, you shrink it to 640x480, upload it and then put an IMG tag around the link that bimmerfest gives you for the uploaded photo.
Old 01-25-2010, 08:13 PM
I defer to you Mack on the hoses.. I did the entire refresh as CN90 suggested including hoses and thermostat and expansion tank etc. I just didn't think the t-stat or hoses needed replacement on my car and I had 137k miles. And with BlueBee having a meer 80k, I thought radiator alone (and maybe expansion tank) would leave him in good shape. But honestly, what do I know....
CL
2002 525i 164k
1988 911 Cabrio
Greater Boston, MA
