Squeaky Sunroof - Bimmerfest - BMW Forums
Old 01-21-2010, 04:11 PM
MarkusBMW MarkusBMW is offline
Inventor of Hotcross Buns
Mein Auto: 650i Edition Sport
Squeaky Sunroof
Mine squeaks when it's closed. Tilt it and it goes away. Is there something I need to lube?
Thanks!
Old 01-22-2010, 08:47 AM
enamoured enamoured is offline
Mein Auto: 2005 BMW X3 3.0i
I'll venture a guess and say the rubber seals around it. Silicon free rubber lubricant, Gummi Pfledge (dunno if they still make it) or any other as long as there is no silicon.
(OO \ (|||) (|||) / OO)
Old 01-22-2010, 08:49 AM
Thanks! I'll try it!
Old 01-22-2010, 06:25 PM
TheCritic's Avatar
TheCritic TheCritic is offline
Mein Auto: 2007 BMW X3
I'm also having this problem. If the sunroof and cover is closed, the cover squeeks/chatters most of the time. If I push up on the cover with my hand it stops (only while I'm pushing on it). It used to also go away in the vent position, but has begun making some noise in that position too now. And when the cover is all the way open there's some chattering from the glass towards the back. Mentioned to the dealer last time I was in, they fixed something else (rubber bellows things had come off) and pretended that was all it needed.
Please report back on what you use and how well it works!
2007 X3 3.0i, Monaco Blue with black leather. AT, Sport: 19" staggered replaced with longer lasting 18", Premium, NAV, Heated Seats.
Previous: 2002 Jeep Liberty Limited ; 1999 Mercury 'new' Cougar ; 1987 Mercury Merkur XR4ti
BMWCCA Member since 10/2008
Old 01-25-2010, 11:11 AM
Jedi54 Jedi54 is offline
Mein Auto: 2005 X3
sunroof in my last two cars have had similiar symptoms and a little bit of properly placed White lithium grease always seems to do the trick. Might be worth a try
Old 01-25-2010, 11:48 AM
Thanks very much! I'll give it a shot!
Old 01-25-2010, 12:53 PM
JBasham JBasham is offline
Still driving my '79 323i
Mein Auto: 2009 X3 3.0; 1979 323i
What year X3? Up through at least 2006 a significant number of X3's developed this as a manufacturing defect. Some described it as a squeak (I had a squeaky one) and others decribed it as a rattle. The solution was dealer replacement, under warranty. Typcially you had better luck getting speedy replacement if you complained about a "rattle" to the dealer instead of a "squeak." I do not know whether it continues to be a problem in 2007 & later models.
Old 01-25-2010, 01:08 PM
Thanks for the info! It's a 2007.
Old 01-25-2010, 02:14 PM
Mein Auto: 2005 X3
I went to Kragen for the lithium grease and they only it in a spray can, do not get that. It's a pain in the a$$ to work with because you'll end up spraying the grease everywhere.
Home Depot usually carries the grease in stock.
Old 01-25-2010, 02:27 PM
Ah...OK...thanks very much! I'll go grab some!
