Drive control malfunction / drive moderately - steering angle sensor error - SZL - Bimmerfest - BMW Forums
Old 01-27-2010, 05:55 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Post Drive control malfunction / drive moderately - steering angle sensor error - SZL
As we all know, on our E65/E66's the steering angle sensor will occasionally freak out and throw an error, with the supporting evidence being a non-self-canceling turn signal. After a little while (typically car stop/start) it will go back to acting normal.
Well, mine finally freaked out again this morning and I was able to pull the error. You'll notice that it only happened once, and that it was just for a split second.
I'm not soliciting advice on this, just providing a little information back to the community. Attached are some screen shots from pulling the error using INPA.
ID:	216345   Click image for larger version
ID:	216346   Click image for larger version
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 01-27-2010, 06:09 AM
gman750 gman750 is offline
G Trues
Mein Auto: 2007 BMW 750Li
could you maybe explain what some of the info means on those screens for the folks like me who have no clue what that is?
2007 750Li, Titanium Silver Metallic,Convenience Package, Luxury Seating Package, Comfort Access System, Cold weather package, 19" alloy, SAT/HD
Old 01-27-2010, 02:36 PM
Master Tinkerer
Sorry...
  1. The first picture is how to get to the SZL / "Satellite steering column" module from within INPA.
  2. The second picture is just a bunch of crap you'd expect to see when you look under identification for this module.
  3. The third picture has the actual error that I got, and some other stuff.
    • "ECU: SZL" ...SZL is the actual module name
    • There is a line specifying both the error number and description, "94E7 / Steering angle sensor: Relative wiper angle faulty".
    • "Error counter: 1" just says that the issue happened once in this instance.
    • "Error present now and already stored" just means that it still thinks the error is there (I didn't turn off the car before pulling this stuff). Once the car was shut off and turned back on, the module rechecked the sensor and determined that all was okay again (after this it said that the error was no longer present, but was already stored).
Old 02-07-2010, 12:08 PM
kwang0429 kwang0429 is offline
Mein Auto: 2006 750i
I got the same problem today, but the good thing is, turn off the engine went for a pick up, came back and restart, it's now gone just like how u described it. thanks!
Old 02-07-2010, 03:39 PM
haz1's Avatar
haz1 haz1 is offline
Mein Auto: 2005 745i
Originally Posted by Keif View Post
Sorry...
+1, Keif it looks like the counter tells how many times the error happened, but does the machine tell operators what date it happened and time? Or does the error have to occur while hooked up to the machine when in the shop?
05 745I 58K
88 735-gone 288K
80 320 gone 300K
76 280Z 2+2 RIP 325K
Old 02-07-2010, 06:59 PM
Master Tinkerer
In INPA by default it just shows the mileage (in KM) when it happened. I haven't checked using any of the other tools yet (DIS, etc.).
Old 02-07-2010, 08:24 PM
haz1's Avatar
Right on.
05 745I 58K
88 735-gone 288K
80 320 gone 300K
Old 10-20-2011, 08:02 AM
italiano italiano is offline
Mein Auto: 2007 BMW 745li
Does anyone know how to fix the problem? It goes away after a restart but annoying.
Old 10-20-2011, 12:33 PM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Lol yes you need to replace the sensor. I had the same issue taken care of under warranty. Mine would only trip after turning the wheels close to or full lock, such as backing out of my driveway.
Old 10-20-2011, 04:40 PM
quarterto8's Avatar
quarterto8 quarterto8 is offline
Send a message via MSN to quarterto8 Send a message via Yahoo to quarterto8
Mein Auto: 2004 bmw 745i
Lmao at gman750 reply! Bro I've known keif for a long time now and when he starts talking bmw he goes into a zone and pretty much no one really knows what he is saying!
2004 BMW 745I (SOLD)
2014 BMW 750LI
2008 BMW ALPINA B7
2016 JEEP GRAND CHEROKEE
Old 01-19-2012, 07:54 PM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
same problem how to replace it ?
Old 01-20-2012, 07:04 AM
wjjklj's Avatar
wjjklj wjjklj is online now
Mein Auto: 2013 BMW M5
Keif,
The third screenshot says on the last line that this would not cause a warning light to come on.
Every time I have had this happen (maybe 3 times in 3 years) I have received a warning light saying to drive moderately. Why does INPA say it will not show a warning light?
Old 01-20-2012, 08:33 AM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
I have this twice, once a year, when i put on my winter tires, but not happened this year thanx God
Old 01-20-2012, 10:07 PM
Master Tinkerer
Originally Posted by wjjklj View Post
Keif,
Good question... The best I can figure is that the steering angle sensor itself doesn't cause a warning, but the failed state of the ARS/DSC system does.
Sent from my ADR6425LVW using Bimmer
Old 01-21-2012, 08:57 AM
Nikki1169 Nikki1169 is offline
Mein Auto: 745li
catalytic converter
my catalytic converter is stopped up on my bmw 745 li. any suggestions
Old 01-22-2012, 07:10 PM
AceFX AceFX is offline
Banned
Mein Auto: BMW 760Li BMW X5 4.8iS
Have you checked the ZGM (gateway module)
As far as the Cat goes..... can they be cleaned? They sure are expensive to buy.....
Old 01-22-2012, 08:31 PM
Mein Auto: 745li
What is that?
Old 01-22-2012, 08:57 PM
Banned
What is what?
Old 10-29-2012, 02:01 PM
vernon3rdw vernon3rdw is offline
Vito
Mein Auto: 7 series
Do u have any idea how much without the warranty it costs
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Old 11-18-2012, 06:35 AM
seannypoo seannypoo is offline
Mein Auto: 2004 745li
i have this problem as well, and i cannot reactive my DTC
Old 03-11-2015, 06:17 AM
Red.donzi Red.donzi is offline
Mein Auto: 2008 750li
Steering angle sensor seems prone to acting up in wet weather
Had this issue come ip twice in past six months and both times in super rainy weather. After driving and and restarting, gone.
Might have already been stated that moisture affects, so sorry if redundant.
Old 09-14-2015, 03:06 PM
jayblack69 jayblack69 is offline
Mein Auto:
I'm having the same problem after unhooking my battery to install an aftermarket amp/sub....now I keep getting the "Drive Control, Drive Moderately!" Light/Warning "PLEASE HELP!"
Old 09-14-2015, 04:56 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
have you checked your battery voltage ???
Your after market amp might be draining your battery ...
Old 09-14-2015, 05:03 PM
Mein Auto:
Thanks PAPER, that might be my problem.....I have a 2 farad cap but it might not be enough and I think it might be draining my battery
