E46 (1999 - 2006)
Old 07-17-2009, 07:19 AM
magnuzza magnuzza is offline
Mein Auto: 1999 BMW 323i
Shock Sensor DIY?
I did "search" it but apparently I can't find the working one. If you can help me find it, I will really appreciate it.
Thanks.
Old 07-17-2009, 07:20 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
What's a shock sensor?
Old 07-17-2009, 07:28 AM
Solidjake's Avatar
Solidjake Solidjake is offline
The one and only
Mein Auto: 2002 330i
The DEI shock sensor that you can hook up to the OEM alarm.
Courtesy of JCsE46
1.) Area of install (see pictures). We will be splicing the sensor into the hood-pin trigger wiring.
2.) Unplug wiring harness, note that the purple wire is what we will be splicing into.
3.) Connect the wires... Yellow to Ground (NEG), Red to constant 12V (POS). Choose the wire of sensitivity and splice into the purple harness wire previously mentioned (Blue/Low Sensitivity, Green/High Sensitivity)
4.) I mounted the shock sensor along the plastic housing near the back since it wasn't the vehicle body or a metal part (per DEI instuctions). This area is also flat and more susceptible to shock. 3M heavy duty two-sided tape was used to mount sensor (P/N 6010ES) as it is strong and resistent to heat.
5.) Cleaned up install with wire housing tubing and tucked the power lead underneath the weatherstripping running along side the strut tower.
ID:	193614   Click image for larger version
ID:	193615   Click image for larger version
ID:	193616   Click image for larger version
_______________Going to Bimmerfest East AND West
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 07-17-2009, 09:58 AM
Courtesy of JCsE46
Thank you!
Old 02-02-2010, 03:32 AM
Abuja_325i Abuja_325i is offline
Send a message via Yahoo to Abuja_325i
Mein Auto: just bought 530i 2004
Hi there KrisL. So, did solidjake ever sent you a reply to your question?....I'm very curious to know what is a shock sensor. where can 1 buy it?
'04 530i (Black)
Old 02-02-2010, 04:36 AM
MicahO's Avatar
MicahO MicahO is offline
In my own cars again
Mein Auto: 330i ZHP
You are kidding, right?
--Micah O'C
CCA 193374
'88 M5, Bilstein Sports/ST Springs, staggered BBS RS, Euro conversion
'04 330i ZHP, Jet Black 6spd, hot seats, LightWerkz TFX-Xenon, Bilstein PSS10
UUC Strut/SwayBarbarians, PowerFlex CAB/TAB, Performance Gearing 3.38 LSD
Old 02-02-2010, 04:41 AM
Macho (???).
I fail to get your sarcasm.....
No, I'M NOT KIDDIN' !!
'04 530i (Black)
Old 02-02-2010, 05:01 AM
MicahO's Avatar
Mein Auto: 330i ZHP
Macho (???).
Not macho - never went for that chest thumping stuff.
Read Jake's post. Again. You read it enough to know that he was responding to the question, but somehow failed to see the answer therein.....
--Micah O'C
CCA 193374
Old 02-02-2010, 07:11 AM
Solidjake's Avatar
The one and only
E46's DO NOT have factory shock sensors. Notice how some cars alarm goes off if you hit it or some big truck drives by? Thats what it's for.
Old 02-02-2010, 07:26 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Thanks Jake!!
I rem some cars would say "please step away from the vehicle" when I walk by. I though it was weird.
mujjuman
Old 02-02-2010, 08:59 AM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Ah, so it scares away the neighbor's cat when it tries to nap on top of the car... Sounds useful, hate pawprints on the paint...
2006 325Ci
Old 02-02-2010, 10:17 AM
Solidjake's Avatar
The one and only
Well, Ford has a special cat system that does a little bit more than "scare" them away.
Old 02-02-2010, 10:41 AM
Mwahahaha! Delicious!!
2006 325Ci
