wont turn over - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-31-2010, 02:40 PM
mikeydbmw mikeydbmw is offline
Mein Auto: acura
wont turn over
2001 330 ci Penny got stuck in cig lighter. Sparks - pulled fuse removed penny now Car won't turn over. Is there a reset for the alarm or is this fuse issue. Car was running fine until then. Thanks for all help
Old 01-31-2010, 03:09 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Check all of your fuses.
Old 01-31-2010, 03:10 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Ugh. That can't be good.
SJ is right, probably need to start with the most obvious - a fuse got whacked and is in need of replacement.
Is there anything at all that's working? Might be an idea to help eliminate the good circuits...
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 02-01-2010, 02:40 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Any chance when you were pulling fuses you put the fuse back in the wrong spot? Something similar happened to a friend of mine.
Tim
Old 02-02-2010, 10:52 AM
Mein Auto: acura
fuses
Thanx - I did have problems checking and replacing a couple of fuses, but got them back in correctly. Are there other fuse locations beside main site in glove box? Sometimes there are some fuses in engine bay (off battery) and in cabin (under seat) for example.
Everything seems to work otherwise. Radio, dash display, lights, central locking, etc. Any thoughts on what other possibilities would be after eliminating fuses?
appreciate it
fuse, immobilizer, short, sparks
