Can a slow leak in a Run flat be plugged? - Bimmerfest - BMW Forums
Old 02-03-2010, 06:27 PM
nupe009 nupe009 is offline
Mein Auto: 2008 650i
Question Can a slow leak in a Run flat be plugged?
I believe that I have a very slow leak in one of my tires. I've read that you can't repair a run flat tire but I was wondering if a slow leak could be repaired. I wouldn't want to buy a new tire due to a slow leak.
Old 02-03-2010, 06:34 PM
docpaulo docpaulo is offline
Mein Auto: 07 650i Convertible
usually a slow leak is at the rim vs the tread or at the valve...
I'd bring it to a tire shop so they can dunk it in water to see if the leak can be found... if none are seen, I'd leave it be and top it off, consider nitrogen fill (they claim it minimizes leaks - but I don't know) or have it unmounted and remounted and the rim cleaned..
if the leak is at the tread through a hole, you can repair it... since it's never been driven with extremely low pressure (or has it)...
07 650i Cabrio CPO, Titanium Silver
Black Matte Grill
Dark Birch Wood Interior and Shifter
HUD, Cold Weather and Sports Package
Logic 7 Sound
Aluminum Racing Pedals
K&N Air Filters
Rays Master Piece REM 20" Forged wheels w/ Conti Extreme DWS
Old 02-03-2010, 06:56 PM
Thanks for the info. I've never driven it with extremely low pressure. I've only owned it for a little over a month so I'm not sure what was done before I owned it. I'll take it to a tire shop soon.
Old 02-03-2010, 07:03 PM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2017 540i
+1 - as long as it's not in the sidewall. When the tire comes off to be repaired, be sure there is NO crease in the inside of the sidewall (this would indicate the RFT has been used), in which case, I'd suggest getting a new tire.
Nick / TopDownInFL (sans the "top down")
2017 540i - Carbon Black Metallic | M Package | Lots of bells and whistles
Previous Bimmers:
2012 650i Coupe
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 02-04-2010, 03:23 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
I agree with all here. A slow leak could be nothing more than a bad seal (I experienced that with a SC430 once) and remounting the tyre will fix it. Personally, I do not recommend plugging a run flat (this is where raod hazard insurance for wheels and tyres pays off).
Good luck!
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 02-04-2010, 08:18 AM
TimDogg's Avatar
TimDogg TimDogg is offline
Who u r, u r forever....
Send a message via Yahoo to TimDogg
Mein Auto: 2004 645ci 2008 535i
i once plugged a runflat tire while on a roadtrip. I was going to replace it once i returned home but got curious as to how long it would last. 23,000 miles later i replaced it!
Never once had any indication that it was a plugged tire.
*it was hell getting the plug in it though, that's one stiff Mother!!!*
Yes, I collect stamps....PASSPORT STAMPS!!!
Red 1998 Ferarri 355 Berlinetta F1, Black 2004 645ci, Space Gray 2008 535i
Old 02-04-2010, 09:25 AM
it all has to do with sidewall damage when the tire is driven with no pressure... since the manufacturer can't tell if the tire was driven in this condition or not, they (for liability purposes) recommend against plugging (also increases sales of a low volume tire)...
but if you are 100% sure it was never driven without pressure, then plugging a hole in the tread area should be no different than non RFT... a tire wall puncture is a different issue...
But I have hazard insurance so I for one will be getting a new tire if I get a hole...
Black Matte Grill
Logic 7 Sound
K&N Air Filters
Old 02-04-2010, 10:53 AM
acmw acmw is offline
Mein Auto: bmw
yes it can, i just had mine plugged 2 days ago.
Old 02-04-2010, 06:47 PM
BADRIDES's Avatar
BADRIDES BADRIDES is offline
Mein Auto: BMW 650 I SPORT PKG
Patch mine good hear for a year
[/SIGPIC]BMW M6 Cabrio Alpine White with Indy Red interior
Mods
Rpi scoops and filters with block off plates
Vorsteiner carbon lip,Deck wing and Rear diffuser
Black mantle grill
H&R 15mm spacers for front and back Go Wide
Painted front and rear brake calibers with M logo
Exhuast rensinator delete with cats removed
Lexus L 460 touring package Family car
Svt mustang Cobra racer
Lexus Gs Modded Daily
Bmw 650i Cabrio Sold
Saleen s 351
Old 02-04-2010, 07:57 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
This is also my opinion of patching RFT's.
Old 02-05-2010, 06:20 AM
dcabot dcabot is offline
Mein Auto: '05 645 Convertible
Better off patching. Plugs are not an acceptable repair for run flats as per my tire dealer.
Old 02-06-2010, 06:48 AM
cherbaka cherbaka is offline
Mein Auto: 2006 BMW 650i
I'd suggest you first get the tire and the wheel it's mounted on tested in a dunk tub. I had a similar problem last summer and made the assumption it was the tire. Nobody here would accept patching it, so I could either get a new RFT tire (approx $500 for the tire and mounting) or I could buy all new non-RFTs all around (the RFTs looked like they only had about 10,000 miles left on them). So I replaced all the tires with non-RFTs (cost me $1100). A week later one of those new tires was low on pressure. Turned out my rim had a small little crack all along that was causing slow pressure loss. It took $50 and a couple of days for a local shop to have the rim repaired. No issues since.
2006 BMW 650i
Old 02-06-2010, 04:34 PM
jamie645ci jamie645ci is offline
Mein Auto: BWM 645Ci
i get punctures every month & just take it to the tyre shop to get it fixed. Of course if there is any damage to the tyre wall then it's a new tyre.
With regards to filling it with nitrogen it does reduce road noise and I noticed a slight improvement in mpg. But I still got punctures though.
Old 04-18-2013, 12:25 PM
jzcrna's Avatar
jzcrna jzcrna is offline
Mein Auto: 2012 BMW 335i Sedan
Had a slow leak that I filled two times in the past three weeks. went and got it patched for free today at Discount Tire
2008 BMW 335i Retired
2009 BMW 535i Retired
2012 F30 335i Retired
2013 VW GTI Driver's Edition with APR Stage 1(Retired)
2016 BMW 550i MSport (Lighting package, Executive Package, Luxury Seating, Drivers Assistance, Drivers Assistance Plus)
Old 04-18-2013, 12:53 PM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
I had a 545i sport with 18" runflats years before I knew about this forum or the differences in runflats other than that they ran flat. I had my tpms light come on and had the tire plugged for $10 at a gas station. I must have put at least 10k more on those tires before I sold the car.
Would I do it again? No, but I didn't have any problems with mine and I drove that thing like I stole it daily. Now I would probably just use it as an excuse to upgrade to some nice non runflats.
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
