X3 E83 (2004 - 2010)
DIY: Disbale X3 seat belt chime
So I finally got around to fixing the seat belt chime problem on my X3.
A few weeks ago, I had my indy BMW shop program my 2006 X3 to disable the seat belt chime and to turn off the chime when it gets below 37 degrees. Unfortunately, the programming does not work on US spec cars--despite the fact that the Autologic displayed the chime as disabled. Blah. So here's my DIY on removing the seat belt chime... Step 1: Remove instrument cluster. 2 Philips head screws holding it in. Remove screws, then pull out cluster and disconnect cable harness. Step 2: Remove back of instrument cluster. There are 4-5 tiny torx heads screws holding the back of the cluster together. Remove them, then gently pry the rear of the cluster off with a small flat head screwdriver. Step 3: Remove speaker. With the back off of the cluster, I turned the car on, found the source of the noise, and err solved the issue. There is a small speaker held on by 2 solder points. Gently sway the speaker back and forth until the connections sever. Step 4: Reassemble cluster. That's it... We read the cluster with the Autologic for faults, and it came up clean... The whole project took about 15 minutes to complete, and I am much happier without the ear-piercing beep every time I throw my laptop bag on the passenger seat...
2004 330i ZHP (me) 2006 X3 (wife) 2004 325xi (sold) 2001 325i (sold) MY DIY write-ups MY Garage (all the mods) Last edited by sna77; 02-06-2010 at 06:30 PM. |
You mean you don't put a seat belt around your laptop bag?
lol. Still great to see a classic BMW issue solved with a quick unplug-and-go DIY.
![]() VISIT MY GARAGE TO SEE ALL MY MODS: http://directory.e46fanatics.com/use...rMod&UcId=7917 |
My 01 and 04 e46 never made the damn beeping noise... I've heard the new F cars don't have the damn chime either. So apparently BMW only planned to punish people who bought cars in the last 4-5 years...
2004 330i ZHP (me) 2006 X3 (wife) 2004 325xi (sold) 2001 325i (sold) MY DIY write-ups MY Garage (all the mods) |
Wow, that's great Steve, leave it to you to figure that sucker out!!!
But doesn't this also mean you'll lose the chime for everything else?
- the warning lights... - Escort 9500i boot up noise - Laser jammer beeping at bootup - kids asking to turn on the DVD players - my wife complaining about something. Anything to reduce overall car noise I'm a fan of... What else is it for anyhow? I know of: - seat belt - 37 degrees - key in the ignition All 3 of those I can gladly live without.
Or just maybe he should get a good pair of ear plugs
cheers vern
Now when you sell the car does this mean you will have to go back and re do everything and put it all back?
Good job Sna, I know several here could use your instructions, I never thought it was that easy. |
This looks like a promising modification. The chime is a nuisance and there should be a way to disable it via on-board adjustments. On two previous vehicles (Ford products) I had, you could locate the part that was bleeping, simply unplug it and consign it to the trash.
Does this improvement work on 2008 X3's? Will this modification produce any check lights?
2008 BMW X3 2006 Porsche 997 2S Cabrio |
Well, you might be surprised at who would be asking why the chime is disabled. I suspect any dealer would have to reconnect things as a safety feature, before reselling the car. There may also be an insurance issue with the buying party's company for a private sale. Not to mention any state DMV issues that may or may not be affected. While its your car you can pretty much do what you want to it (broadly speaking) but when you are transferring it to another party it becomes another story, especially a dealer as a trade in. I know that if I was buying a car that had safety features (however useful) disabled I would want everything put back together to insure against potential liability issues. Good luck in any event!
Sna77, great idea. Luckily my 2007 does not beep nor chime because of the seatbelt.
Cheers! |
http://www.realoem.com/bmw/showparts...63&hg=62&fg=05 No lights out at all on my car. The seat belt light stays on just like it would before if you aren't wearing your seat belt... only without the annoying chime. This is as simple as simply unplugging the speaker... Quote:
The chime is deactivated by default in the rest of the world. Only sure happy USA gets the chime turned on by default. I watched the tech as he tried to disable the chime via the Autologic--there is definitely a button to turn it on an off. He contacted Autologic after attempting to disable the chime via software coding did not actually disable the chime. Apparently USA spec cars had something in place that renders BMW's coding ineffective.
- replaces the missing (annoying) chimer with a much more subdued pleasant-sounding one The next project after that will be to: - bring a microprocessor into the mix that sends a text message to the GPS screen that says, "Passenger - please fasten your seat belt", or, "The air temperature is below 37 degrees". |
I was actually thinking that you could probably put some microphone foam over it to deafen it a bit... The most annoying thing about the chime is its obtrusive volume...
I need a DIY for that as well
Sorry, if will be rude. My apologies in advance!
But I cannot help say that this is the most brutal way to solve an issue. I mean, good god, do you have to literally "break away" the speaker from the instrument cluster, just because you do not want it to chime??? So, next time just break anything else, just because you do not want it to work !!! Gosh, this is insane!
Jude Mauritius Tel: +230.7409000 |
Interestingly enough, my 2003 M3 has no chime; only an icon. My 2001 Audi didn't have a chime either. I hate the chime on this car and if have the time, I'll pull the instrument cluster and put tape over the speaker. |
Sna77 --this the same thing? Also, surprised you didn't just get some copper desoldering strap and remove it?
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
Hi all,
My first post at Bimmerfest. I wanted to 'chime" in on this thread, as I have always found the seat belt/key chime annoying, and now that we're getting 30 degree temps here in SE TX, I really don't need the frost warning going on and off. I've just taken care of the problem on my '07, and there are a couple of points I'd like to add to the origin (very nicely done) DIY. The '07 uses T10 screws on the cluster, not phillips head, and the small screws holding the back of the unit on are T9 (not too common, make sure you have one before you take the cluster out). Almost all the noise comes out the hole in the back of the chime. Rather than break it off, I stuffed some foam in the hole, secured the foam with a small piece of tape, and put another small piece of tape over the little grill on the back of the cluster. The volume has been reduced to almost nothing, barely above the threshold my airplane/motorcycle damaged ears can detect. Last edited by dutchhollywood; 02-05-2011 at 06:50 AM. |
#25
