Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 01-23-2010, 02:17 PM
brewster brewster is offline
Mein Auto: 1997 BMW 740i
How do you replace Check Engine Light?
I have a 1997 BMW 740i. The car was sending a transmission fault code but drove fine. The Check Engine light was on for quite a while. I finally replaced the transmission but then the Check Engine Light burned out. How do I replace it.
Old 01-24-2010, 12:57 PM
04SSHD 04SSHD is offline
bigdaddyfatsac.com
Send a message via AIM to 04SSHD Send a message via MSN to 04SSHD
Mein Auto: nothing
It's a LED soldered onto the gauge cluster circuit board. It's not easily replaceable
Old 01-25-2010, 09:21 AM
Thank you
I guess I'll need a qualified mechanic.
Thanks,
Brewster
Old 02-07-2010, 06:22 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
I'm pretty sure it's just a bulb that is easily replaced along the bottom row of the cluster.
To the OP : Remove the cluster and double check the bulbs, they can be bought at the dealership for a few bucks.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
