Old 02-10-2010, 05:47 AM
How to tell if your E39 has the high or low instrument cluster
I didn't know this little tidbit until yesterday (many thanks to QSilver7!) so I post his diagrams to help others.
If you need to know whether your E39 has the high or low instrument cluster, look for one of the (at least) three telltale indications:
HIGH instrument cluster:
- Two stalk buttons, one on each side
- 20-digit alphanumeric display at the bottom center
- Oil-service interval light to the left of center
LOW instrument cluster:
- One stalk button (to the left of center)
- No 20-digit alphanumeric display at the bottom center
- Oil-service interval light to the right of center
Old 02-10-2010, 05:54 AM
And, if you need QSilver's instructions on how to unlock your instrument cluster, go to his web site here.
To help others, I combined QSilver's separate OBC cluster-unlocking JPGs into single PDFs (compressed to less than 1Kb each).
Old 02-10-2010, 09:06 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Nice work again Bluebee...hopefully those who need the instructions to UNLOCK their OBC will take advantage of your efforts in turning the instructions into a downloadable PDF.
Here's something else you may want to add...the HIGH clulster & LOW clusters also come with different MIDs (multi-informational displays). The LOW cluster comes with the LOW MID (no BC button)...and the HIGH cluster comes with the HIGH MID (or the Nav screen/monitor):
And nice additional "red ink" on my High/Low Instrument Cluster images, too.
Q {BMW CCA Member #191509}
(SOLD)
Old 02-10-2010, 09:27 AM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
The high MID is what I miss the most about the high system.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 03-01-2010, 06:18 AM
To help others searching for information once they unlock their OBC ... I was searching for a description of how the fuel injectors (really) worked when I found this additional site for diagnostic information once you unlock your OBC.
Exploring the E39 OBC
Old 04-15-2011, 10:49 PM
For the crosslink record, for those with the low cluster, here is a video posted today for unlocking it:
E39 (1997 - 2003) > Low cluster - Access your engine temperature
Old 03-13-2013, 05:33 AM
Just ran into this retrofit PDF while looking for low to high obc cluster retrofit information.
It seems that PN 65900308455 allows you to retrofit a low cluster to a high cluster.
ID:	366155   Click image for larger version
File Type: pdf BMW_E39_E53_Low-to-High_OBC_Retrofit_kit_PN_65900308455.pdf (779.8 KB, 771 views)
Old 04-08-2013, 12:43 PM
For the record, apparently some E39 clusters show test #9 voltage with the decimal place and the units abbreviation; while others don't, according to information in this thread today:
Originally Posted by nalaleah53 View Post
I'm also attempting to show a "OBC test #9 alternator and a battery voltage display. Does anyone else's display look like this without the word "volts" and a number like 13.5 with a decimal point showing? Am I really not doing a voltage test even though I drop it into test #9?
Originally Posted by rdl View Post
Regards test #9 - you have the "low" or Kombi instrument cluster; same as mine. The test 9 display is exactly like mine. Your pictures are indicating a voltage of 11.5 volts.
versus
Old 10-20-2014, 01:39 PM
This information about the low cluster today is too good to not reference in this canonical thread ...
Originally Posted by QSilver7 View Post
When you press that BC button, your low cluster's OBC should reveal the other 3 features:
ID:	470894   Click image for larger version
ID:	470895   Click image for larger version
Old 10-26-2014, 06:30 AM
There are so many good graphics from QSilver7 that I don't know where to put them, so, I'll add the ones from this thread today so that others can more easily find them:
> E39 (1997 - 2003) > 1997 low cluster
The instructions for resetting the (low) OBC is in the very last paragraph...after the text that is underlined in blue:
