7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
DIY Reference - Battery registration
I'm looking to replace the battery in my 2002 E66, 745Li
I found the useful thread in the DIY section http://www.bimmerfest.com/forums/sho...d.php?t=419230 However, it says "Don't forget to register the battery once the new one is in." My question is...... HOW? I heard this was a dealer only thing..... Is it? Thanks |
Yep, registered mine with INPA (using a VAG-COM KKL interface). No problems. INPA has a more simple interface (and is easier to set up) than DIS. If you're a software guy, you should have no trouble getting this stuff running.
Also, find the thread in this forum (not the DIY forum) with the same title as the one you linked to. There is some useful info there (like the shortened version of replacing the battery -- gracias, Haz1).
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
Thanks to all that helped directly and indirectly with their posts on here.
I got INPA working with my E66. Now just to find a new battery (90Ah AGM), and then find the option somewhere in INPA. Cheers! |
I got INPA working, but my battery has finally died, so I'm ordering a new one from BMW.
Can anyone point me to where the option is in INPA to do the battery registration? Thanks |
Power module
HI Keif,
Sorry to sound a bit dumb, but could you confirm which option it is in the Power Module bit? I have the following <F1> Information <F2> Identification <F4> Error memory <F5> Read status <F6> Activate <F7> Read memory <F8> Select <F9> Print screen Not sure which one is for Register battery.... Any info appreciated. Thanks |
Thanks to Keif and the folks on here for helping me with this.
Just to feedback..... If you have INPA working, then select the following to Register the new battery 1. Select BODY from the left hand pop-up menu 2. Select POWER MODULE in the right hand list 3. Select ACTIVATE from the next menu 4. Another menu comes up, which has ACTIVATE1 and ACTIVATE2. 5. Select ACTIVATE2 from the menu 6. Then select F7 - Register battery replacement Almost instantly you get the message: "Register battery replacement Activated properly." Job done! Hope this helps! |
Might want to repost this or ask for it to be reposted in the DIY section. Surely many will find this useful! Good stuff, glad everything worked out!
