Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
Z3 (1996-2002) and Z4 (2003-2008)
Z4 Backup camera
Hi all, I'm new to this forum but driving my '08 Z4MC for more than a year, now i'm looking for some info about my next project "the backup camera project" does somebody know something about this? Done this? or know someone who has done it? Thanks in advance!!
Ron Stygar on this forum did that and documented it heavily. Do a search on backup camera or his name.
Pat Casey 2005 Z4 2.5i |
Thanks Caseysc1 if found http://www.bimmerfest.com/forums/sho...+stygar&page=3 Nice mods but no manuals or wiring instructions of any kind. I orderd
http://www.autostyle.nl/images/produ...s/LH%20102.jpg and added already the video plug to the tv tuner white plug but would like to have some advice about the power 12V and the Pin17 on the blue tv tuner plug |
Ron is your man on the wiring issues. He monitors this forum quite often. Try sending him a private message.
I actually have this
http://www.navvideo.com/navvideo-mod...p?Car=BMW%20Z4 got it for xmas and have been waiting for the weather to warm up a little to install it, I have camera #3 to go in the keyhole, Will be fitting it soon, and I might add one to the front as the module has 2 inputs
![]() Imola Red Roadster
Oh and if anyone is looking for cheap cameras (plus a site FULL of cheap gadgets)
Check this out http://www.dealextreme.com/products.dx/category.709 It ships from Hong Kong so it takes about a week but they have some amazing stuff
oke, seems to go fast around her
Thanks Ron for the link!! found almost everything i was looking for. To support the forum i will try to post my feedback with some pictures afterwards thanks in advance and hopefully i can finish it without any big problems |
Has anyone tried the Garmin Nuvi 5000 as a rear camera monitor using the composite video input ? Since some of us don't have all the new electronics this is probably the best alternative. It can also be stored away when not in use.
I'm curious to how good the video update is.
2005 Z4 2.5i |
Found everything i need and got my camera delivered today
I made a nice wiring scheme to make life easy for future installers.
Well done. Looking forward to seeing the result after install.
Just finished making my cables and did a first test before the final install.
Nice work. Thanks for sharing!!
looking good so far. this is on my list to do (eventually)
Where will you be mounting that camera? The coupes don;t have a rear keyhole like the roadsters (thats where mines going and I have the same camera as you)
So you got the TV tuner module as an option?
Latest update all installed and it works
Here i go,
first i did some research and found everything i needed to do the job on the net. For your convenience i do a step by step. ![]() ![]() Relay ![]() Camera ![]() TV Tuner Blue and white plug ![]() White plug dis-mantled ![]() white plug and AV cable ![]() Ready to test and a plug scheme ![]() Rear lights connector ![]() Looking for the backup light cable ![]() Making the relay ready for installing next to the TV tuner harnaess ![]() Doing some coding with Navcoder on an old laptop ![]() Making cables looking professional ![]() The result ![]() The place i installed the camera close up ![]() The place i installed the camera
Yes i did, i took my coupe fully loaded the only thing i forgot was the AUX and the backup camera so i finally did it myself i also changed the interior lights with pure white gas lamps much clearer now.
Seems like the LED's inside the camera are still getting some power after i shutdown the car the 12V i take from the TV tuner blue plug pin 1 seems to be continuously providing and is not shutoff after the car goes into deep sleep. I'm thinking about changing the 12V from the blue plug to 12V from the backup light himself so the camera only gets power when i put the car in reverse.
Any thoughts about that or other solutions i can look into?
Like i was thinking will change power to reverse light was planning to put a switch somewhere close, where did you build in yours?
http://www.bimmerfest.com/forums/sho...3&postcount=84
Nice readings
Just updated my wiring scheme to the one i used in the end. Powering the camera from the reverse light so it doesn't stay on after i shutdown the car.
