Old 02-25-2010, 08:04 AM
ameritrades ameritrades is offline
Mein Auto: M3
What tire pressure are you running on the OEM 19's w/ Run Flats?
Don't have the door jam here to check.
Thanks in advance
Old 02-25-2010, 05:20 PM
mdernst's Avatar
mdernst mdernst is offline
Mein Auto: 2013 M5
Thanks in advance
32 PSI all around (as per the door jamb).
Current: 2013 M5
Previous: 2012 A7; 2011 S5; 2011 X5M; 2010 750Li; 2009 M3 Sedan; 2008 X5; 2003 M5; 1998 540i 6 spd.
Old 02-27-2010, 09:50 AM
SAMLAMBO SAMLAMBO is offline
Mein Auto: BMW, Mercedes, Ford
I'm running on Pirelli P Zeros run flats 275/40/19 and 245/45/19(same as 750 specs). Not to sure in PSI but the machine reads 240 which the techs pumped on all 4 tyres.
2012 BMW 740i
2011 Mercedes E250
2007 Lamborghini LP670-4 SV
Old 02-27-2010, 04:10 PM
mdernst's Avatar
Mein Auto: 2013 M5
Most likely that is 240 kPa which equals 34.8 PSI.
Mike
Current: 2013 M5
Old 02-27-2010, 07:26 PM
Mike
Is that to much?
2012 BMW 740i
2011 Mercedes E250
Old 02-27-2010, 08:09 PM
mdernst's Avatar
Mein Auto: 2013 M5
Is that to much?
Not necessarily. I think it calls for higher pressures for higher loads and for sustained high speeds.
Mike
Current: 2013 M5
Old 02-27-2010, 11:53 PM
Mike
Ok thanks. Does lower pressures mean more comfort?
2012 BMW 740i
2011 Mercedes E250
Old 02-28-2010, 02:30 PM
Wilassasin's Avatar
Wilassasin Wilassasin is offline
Wilassasin
Mein Auto: 2013 S550 amg sport pack/
How are those runflats, are they loud because runflats generally run louder then regular performance tires..My vette has runflats but thats only because there is no spare, otherwise I would have swapped them out.
Previous: 335i xdrive coupe(sold),745(sold),750 sport(sold).
Current: 2013' S550 4matic, 2016' C7 (stingray).
Old 03-01-2010, 06:30 AM
Not at all. Very smooth and quiet and I'm on 19inch rims, using Pirelli P Zeros. Although I have to admit my previous Jag XJ was quiter but it was not on runflats. However the Jag XJ's have always been very quiet cars. Just my opinion.
2012 BMW 740i
2011 Mercedes E250
