Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series
7 Series & 8 Series
The BMW 7 series and 8 Series Forum
Old 02-16-2010, 07:20 PM
scottbimmer scottbimmer is offline
Mein Auto: 74oil
Red face 2001 740il
DOES THE 2001 740IL COMES WITH AN ALARM, AND IS THE RED LED ON TOP OF THE DASH BOARD AN ALARM INDICATOR. thank
Old 02-25-2010, 07:26 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Hi Scott,
I've moved your thread to the correct forum. I believe you car does have an alarm. When you say the LED on the top of the dash board do you really mean on the bottom of the rear view mirror?
Welcome to Bimmerfest,
Tim
Old 02-25-2010, 09:24 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
Yes. Page 42 of the manual
Link: http://www.e38.org/2001Manual-7Series.pdf
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 03-01-2010, 10:46 PM
Mein Auto: 74oil
Hi:
Old 03-01-2010, 11:27 PM
M.Wong's Avatar
Mein Auto: The E38
Did you read the manual? What else do you want to know?
M.Wong
Old 03-01-2010, 11:36 PM
M.Wong's Avatar
Mein Auto: The E38
Tim
No mirror clown nose on the E38, it's on the dash...
M.Wong
Old 03-02-2010, 08:29 PM
Mein Auto: 74oil
What battery do you recomend for 740il, i read across 9.4v
Old 03-02-2010, 08:43 PM
bmwtime740 bmwtime740 is offline
Owned A Good V8 In My Day
Mein Auto: E Thirty Eight
9.4volts? Thats too weak. You need a 12volt battery.
Rebuilt Motor
283 Small Block 4.6L v8
Bored .030 Over
Forged Dinan Internals
Dinan Stage 2 Engine Software (Chip)
K&N Intake
Eisenmann Dual Catback Exhaust
Borla Headers
EMp Stewart Components High Flow Water Pump
Eagle Racing Cams
3:15:1 e39 M5 Differential Swap(Newest Mod)
Royal Purple Synthetic 10w-30 (Soon to be 15w-xx)
///7
Engine Torque: 365.062
Engine Power: 340.210
Old 03-02-2010, 10:25 PM
Mein Auto: 74oil
thank for your infor. Any battery you recomend
Old 03-02-2010, 10:27 PM
Yellow or Red top Optima, if not that; OEM.
Rebuilt Motor
Bored .030 Over
K&N Intake
Borla Headers
Eagle Racing Cams
///7
Old 03-02-2010, 10:30 PM
Mein Auto: 74oil
Smile key
When i got my 2001 740il i got only one key , how do go about getting two more (2), does the rims come with s/n because i need a spare, and i would like five to be the same. Thank for ans.
Old 03-02-2010, 10:47 PM
Sux. You have to go to the stealer to get more keys, because off the lot brand new the 740i, 740iL and 750iL came with 2 Master keys incorporating remote control transmitters, 1 spare key without remote control function, and 1 valet key that opens doors and starts the vehicle but it doesn't open the glove box or trunk.
Rebuilt Motor
Bored .030 Over
K&N Intake
Borla Headers
Eagle Racing Cams
///7
Old 03-04-2010, 02:27 AM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
new key is about $215 at the dealership, after taxes.
if your battery is reading 9 volts, it likely has one dead cell. if you can afford it, try and get an Exide Orbital. its much like an Optima, personally i think Exide makes a better battery. the one i've had has been one of the best batteries i've ever owned. i let it sit for a year, nearly completely drained. put it on my charger, works like a champ and still has high cranking amps to boot.
in my E38, i have a BMW battery. have had it a year, no problems. it was put in when i bought the car. i figure they are pretty expensive. you do need a certain type of battery for the E38. most of the time you will look for a gel cell or absorbed glass mat type battery, these charge slower and hold cranking amps better than a flooded or wet battery. even though a battery will fit, it wont always last. i've tried to explain this to a number of people when their battery doesnt last more than a couple years or less, its because the proper battery isnt being used.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 03-04-2010, 09:55 PM
Mein Auto: 74oil
Thank for your reply, I hope DURALAST GOLD battery is a good one. I order two keys cost $255.22 from a dealer. Can you tell me, next to the milage i see a -4o F degree what does this mean.
Old 03-05-2010, 03:49 AM
M.Wong's Avatar
Mein Auto: The E38
It's the outside temperature display. (Page 76 of the manual "Odometer, outside temperature display." I really urge you to read it, I posted the link on my first reply.)
When it reads -40 it means it's damaged, disconnected, or missing. It also means your A/C may not work because the car thinks it's very cold outside.
It looks like this and is in front of your front passenger wheel, behind the fog light, visible only from below the car. It's mounted in an indentation on the lower plastic cover.
M.Wong
Old 03-05-2010, 03:19 PM
Mein Auto: 74oil
Thank you, is it some thing i can fix myslef or a dealer should do it. have you ever repair it your slef.
Old 03-05-2010, 03:48 PM
M.Wong's Avatar
Mein Auto: The E38
You need to look under the car, if it's there you can just swap it out. If it's missing, you have to see if the wires and plug are there. If not, then you may or may not want to take it on yourself.
M.Wong
