7 Series / 8 Series
The BMW 7 series and 8 Series Forum |
Service Indicator Display: fuel is only value used to determine ''load''
I was researching info about the e39/e53 (X5) low instrument cluster...and ran across the info below that went into greater detail about SIA III (service indicator display III).
Before today, I was still INCORRECTLY assuming that the same values used in SIA I and SIA II (fuel, mileage, engine temp, RPM) were still being used to determine "load". The old SIA I formula was e=a(1+t+r) where:
So under this old calculaton, if you drove 5 miles with a cold engine @ 5000 RPM...the SIA I would calculate "e" as 12.5 miles although you only drove 5 miles:
But starting with the 1996 model year...BMW started implementing SIA III where fuel is the ONLY value used to calculate "load"...see the info below for more details: ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
Good to know. Thanks for posting that!
1999 540i/6 MSport- Halos, Facelift Tails, Debadge, Maint Done 2010 Mini Cooper S- Bone stock TURBO 1991 Mazda Miata CSP Autocross Beast. too much to list.. 1981 CB750 Cafe Racer |
