Intermittent Camshaft Position Sensor Fault - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 02-24-2010, 05:30 PM
newscam newscam is offline
Mein Auto: 1992 318is
Last summer my check engine light came on and my 2001 330i started accelerating very poorly. I pulled out my trusty code reader and determined it was the camshaft position sensor on the intake side. I promptly replaced it with a non oem unit. Problem solved, not really.
Ever since, every so often the car accelerates poorly in the same fashion as before. However, it repairs itself almost as quickly as it comes on. My code reader will then show me a cps fault, although the cel has not come on.
Logic tells me this intermittent problem is probably a bad cps. However, before I go and by another one (oem this time,) I want opinions on if there is something else that could be causing this. Like a vanos solenoid or something else. Any opinions would be helpful.
Thanks!!
Old 02-24-2010, 09:46 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
I have no idea, but I did hear that OEM sensors are way better for BMWs
mujjuman
Old 02-25-2010, 06:43 AM
automechanic7 automechanic7 is offline
Mein Auto: 1993 BMW 318i, 2000 528i
aftermarket is good for a lot of things, but when it comes to sensors i would go oem. also check and make sure u have good connections everywhere. a bad or loose connection could cause the intermittent problem.
[SIGPIC][/SIGPIC]Good cars get you from point A to point B, great cars will just get you into trouble.
Old 02-25-2010, 12:13 PM
J. Kidd's Avatar
J. Kidd J. Kidd is offline
Coyote Racing Team
Mein Auto: 2011 Mustang GT
Did you clear the code after you read it the first time? If not, that might be what you are reading (they are stored unless they are cleared even if the problem has been fixed).
That being said, and like others have stated, when it comes to these types of sensors, it is best to stick with OEM. That may mean Bosch or some equivalent, but the ones from the auto parts stores can be lesser quality Chinese pieces.
2011 MUSTANG GT
Premium / Brembo Pkg / 6 spd / 3.73s
Kona Blue with Black/Cashmere Leather
Steeda Sport Springs / Roush Axle Back / MGW Shifter / BOSS Front & Rear Fascia / BMR Adjustable Panhard Bar /
BMR Relocaton Brackets / BMR Lower Control Arms / Staggered AMR Charcoal Rims / Steeda CAI / BAMA Tuned
Old 03-01-2010, 07:08 AM
ECSTuning's Avatar
Instructor of the Stig™
We have sensors available below...
ClickHERE to order or for more information.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Old 03-13-2010, 01:54 PM
sbeck12 sbeck12 is offline
Mein Auto: 330i
Thanks!!
Hello,
Could also be your engine software needs to be updated.
I know mine is from 2000 and the mechanic said it wouldn't hurt to update.
I also get this at times and have stalled twice while stepping on it from stop.
I think I also need the camshaft position sensor.
Sean
