E46 M3 (2001-2006)
Old 02-06-2010, 04:42 PM
johnstks55 johnstks55 is offline
Mein Auto: 2006 m3 convertible
Car shuts off while driving and more
Less than a month ago I brought my M3 in for the Inspection2 which took all of 2 days. The car ran fine before the inspection and now, maybe it coincidence but all of a sudden the car has a clunking sound when I make full turns left or right. Most notible when moving slow . Feels like I ran over something. Then today the car shuts down while making a slow turn through an intersection (scary). Anybody else hear or have this problem and would the shut down be recorded in the on board computer. Thanks, John
Old 02-13-2010, 03:18 PM
MrAdam's Avatar
MrAdam MrAdam is offline
White Mexican
Mein Auto: e90 M3
woah... never heard of this. please keep us posted.
Old 02-13-2010, 05:03 PM
Oldman M Coupe's Avatar
Oldman M Coupe Oldman M Coupe is offline
Oldman M Coupe
Mein Auto: 2000 M Coupe
Check and see if they changed the diff oil, if they did there is a SB about the oil to use for cars making noise on tight turns. As far as the shut down , didit only happen once?
Old 03-01-2010, 01:06 PM
K.Motorsports K.Motorsports is offline
Mein Auto: BMW
clunking could be failing sway bar links... happens ALLL the time. As for the car shutting off... check the terminals, check the alternator (and battery) at a local auto parts store... check oil, oil pressure etc. Start with simple things and advance as needed.
Or just bring it back. Thats what I would do.
Old 03-01-2010, 01:12 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Do you have any codes? Maybe they disconnected the camshaft sensor?
Old 03-13-2010, 03:31 PM
iamadvs1 iamadvs1 is offline
Banned
Mein Auto: 2002 E46 M3
Could be the idle air control valve (IACV). If this little bugger is sticking in the open or closed position then your car will slowly idle down to dead. Putting a load on the engine (ie turning) will exasperate the problem. The engine will start to run rough and then die. The rough running engine could be the noise your hearing.
