Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series
7 Series / 8 Series
The BMW 7 series and 8 Series Forum
Old 12-28-2009, 02:03 PM
hayyan hayyan is offline
Mein Auto: E38 1998
Heat/air issue, and door won't close in cold
Hi guys I have 2 major issues going on with my 1998 740IL
1. Even though the temp Knob in dash is on cold ( Blue) when ever feet/upper button is pressed I still get hot air coming out, sometimes I get hot air coming underneath the seat. So After playing around I have either user auto or straight button ( air would come straight to your face) in order to over the heat issue. Since its winter I don't mind it is big problem in winter. Also sometimes I get only cold air if straight to your face button is pressed so I have either use feet or upper button to get heat.
2. Driver side door is not shutting down when it is really cold , I have googled it but not found a satisfactory solution. Some say use UD-40 or silcion base solution which I have but it didn't work. Any suggestions or do I have change my latch.
Old 03-14-2010, 05:57 AM
jimmyb jimmyb is offline
Mein Auto: 1995 740il
for the cold air in the face make sure the adjuster on the dash is rotated towards the red more than the blue.
i have also had a problem with driver side door not latching. i used a dry lubricant called poxylube and it worked great. sprays like wd-40 will give you problems later as it tends to collect dust and dirt. hope this helps.
door lock, heat
