Dsc and handbreak light - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 03-11-2010, 01:30 AM
!RAY !RAY is offline
Mein Auto: 05 320D
The DSC AND THE HANDBREAK LIGHTS WERE COMING ON NOW AND AGAIN.
Now they are on all the time they are yellow and after about 30 sec they is a beep letting me know the light are on.PLEASE SEE ATTACHED LINK.
http://www.realoem.com/bmw/showparts...=34&fg=25&hl=7
The dsc sensor is number 2 on my 2005 320d 2l there seems to be two sensors beside each other.How hard is it to change this sensor and are they both DSC sensors.
Cheers
Ray
Old 03-11-2010, 05:37 AM
ysoloud's Avatar
ysoloud ysoloud is offline
Mein Auto: 2001 325i e46
it might be telling you you're dsc has went out. because when you hold the dsc button for 10 secs to turn it completely off the brake light lights up yellow.
01' 325i 5spd
Old 03-11-2010, 06:42 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
I helped a friend look into this same problem on his M Roadster (Z3 based) last weekend. Generally you need to start with the wheel speed sensors... clean them, test their resistance with a voltmeter to see if any are not functioning properly. There are other components on his car that could be bad too, but we didn't have the proper code reader to get codes from the braking system, so we didn't succeed at solving the issue.
I'd start there since it's an easy thing to do yourself with a floor jack, hex key, and voltmeter. I believe each sensor should read 1000 ohm resistance across the two contacts, but I'm not 100% on that. I'd read and log all four of them and if any don't match, then chances are that is the one that's bad. If they're all the same, then there is something else wrong.
Jeff R.
Old 03-11-2010, 09:44 AM
dbred330ci dbred330ci is offline
Mein Auto: 2001 BMW 330ci
this happened to me once when i went into a car wash. The car wash had a dolly for the left front wheel. So 3 wheels would spin and the left wheel remained stationay. This seem to cause the dsc to turn off utill the car was turned on then off.
Old 03-11-2010, 03:14 PM
johnewhite's Avatar
johnewhite johnewhite is offline
USMC ProCivEng
Mein Auto: '03.5 M3 Coupe
Check brake fluid level.
Old 03-11-2010, 03:40 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Wheel speed sensor first.... Then dsc module
mujjuman
Old 03-12-2010, 08:23 AM
tk4454 tk4454 is offline
Mein Auto: 2000 328i
how to find wheel speed sensor
i was driveing the other day hit a bump, i know i didnt lose traction but my dsc light came on, im guessing a sensor is loose, how do i go about finding it to check? any help is apreciated thanks
Old 03-12-2010, 08:50 AM
jvr826's Avatar
Is it Trackday yet?
No way a sensor is loose. They fit deep into a hole in the hub assembly and are bolted on. Often they need to be pried out with a screwdriver... that's how snugly they fit.
Jeff R.
Old 03-14-2010, 01:41 AM
Mein Auto: 05 320D
Thanks for all the reply's ill try the wheel sensors first.
How hard is it to replace the dsc module
Ray
Old 03-14-2010, 07:34 AM
TimMWorkman TimMWorkman is offline
Mein Auto: 2001 BMW 330CI
I've got the same problem and I replaced the wheel sensor and it did not fix it. I am afraid it is the DSC module which is big bucks. I don't know if it is a DIY project but would be interested to here what other posters say.
Old 03-14-2010, 09:42 AM
HihoBrian's Avatar
HihoBrian HihoBrian is offline
HiHoBrian
Mein Auto: 2001 BMW 330Ci
A proper scan tool can diagnose all of the sensors and the module. I stoped by an Independant Shop and asked for a scan on a 5 series. 30 seconds later I knew I needed a remanufactured module and all the sensors were fine. OBD 2 scanner may give a generic VSS code but a specialized tool will check EVERYTHING. I offered the mechanic $20 and he told me to "keep it, so I could afford the new module" LOL
2001 330Ci Debadged,Koni Coil overs,Ebay Headers,Meyle HD control arms,RE shock mounts,ADJ BavAuto Camber kit. 18" A/C Schnitzers w/255's,Swaybarbarians,AFE intake,Pred Orion V2 Angel Eyes- AutoX membership confirmed !
