Old 03-12-2010, 07:54 AM
CaptainTrap's Avatar
CaptainTrap CaptainTrap is offline
a man made of men like me
Mein Auto: 2001 330i 5MT ZSP
Summer Wheels going on, tar wont come off
Im prepping my summer v710s for use and want to get some road tar off that has sit on the wheels through the winter. Bug and Tar remover wont take it off. I have a bottle of goof off sitting here ready to go at them. I already tested an inside area and it worked great with no apparent damage to the paint. I immediately washed the area with dish soap and water. Should i continue use or get something less harmful? i have to get this done today and the local autozone only had the bug and tar that didnt work... thanks guys
2001 330i ZSP 5MT H&R Sport Cup Kit 18" VMR v710 18x8.5
BMW CCA #: 399644
Old 03-12-2010, 07:58 AM
Fast Bob's Avatar
Keeping it surreal
There are lots of things which will remove the tar, but most of them (WD-40, Goo Gone and similar products) have solvents which *may* dull the finish, so always try it on a hidden area first. Ronsonal lighter fluid is almost pure Naptha, and is an excellent solvent that evaporates super fast....
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 03-12-2010, 08:03 AM
the tar is on the recessed and inside areas of the wheels and not on the outer face. so if any finish is harmed it wont be very noticeable. still i dont want to damage any part of the finish. the tested area seemed ok. any one else have experience using Goof Off on their wheels?
BMW CCA #: 399644
Old 03-12-2010, 08:09 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
I would skip the goof-off . It's seriously toxic stuff and will destroy paint if it gets near it . I use a citrus based degreaser (finish line or Pedros ) to clean tar off carbon fiber bicycles . It works perfectly and has no affect on the finish . It's available at any good bike shop and similar stuff is probably available at any hardware store.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 03-12-2010, 08:23 AM
968RACER's Avatar
968RACER 968RACER is offline
Registered Loser
Mein Auto: 330CI ZSP ZCW ZPP
I used Goof Off on my paint to remove the gooey adhesive left over from removing my clear bra. It didn't harm my paint what so ever so you should be fine to use it on your wheels.
Old 03-12-2010, 08:25 AM
Cliff Cliff is offline
TMS
Mein Auto: BMW
I have used goof-off to remove adhesive residue from the inner barrrels of my wheels. It's powerful, but it works. I also keep citrus degreaser in the cabinet, but rather than buying the $10 16 oz bottle from my local bike shop, I just get the $10 gallon-size jugs from Home Depot. They're in with the janitorial supplies. (edit: I also give my Campagnolo stuff a bath in the citrus degreaser a couple of times a year - a clean drivetrain is a happy drivetrain)
edit: A friend of mine is starting up a mobile wheel repair business. He was in my neighborhood yesterday and I hadn't seen his trailer/workshop yet, so I went over to check it out. He was in the area to straighten a bent wheel. He cleaned the barrel of the damaged wheel using lacquer thinner and a nylon scraper.
Old 03-12-2010, 08:34 AM
ThreeTwoFive ThreeTwoFive is offline
Mein Auto: B25
Try simple green. Very good stuff. I use it on my wheels and it didnt hurt the finish but idk about v710. You will have to wax the wheel after you use it though. It tends to "dry" it up.
Old 03-12-2010, 08:47 AM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by 968RACER View Post
I used Goof Off to remove the gooey adhesive left over from removing my clear bra. .
I always *knew* you were a kinky bastard.... :-)
(R.I.P. Jever)
Old 03-12-2010, 09:02 AM
scudder44 scudder44 is offline
Mein Auto: 320d SE Auto Touring 2002
LMAO!
I use petrol. Not for my bra you understand, for the tar. No residual damage to laquer or paint.
Old 03-12-2010, 10:17 AM
GoingNuts GoingNuts is offline
Banned
Mein Auto: 04 330Ci M-Sport
The bulk alloy wheel cleaner used by detailers are powerful stuff and they are friendly to the wheel paint.
Old 03-12-2010, 12:09 PM
i tried the goof off and it still didnt get the little specs of tar off. i scraped them with my finger nail while rubbing and some came off but the majority is still baked on there pretty good.
i only had these wheels for one season so far and treated them with 3 coats of rejex when i first got them and continued to clean them weekly. but i made the mistake of not thoroughly cleaning them before their winter hibernation. i also stored them outside so they were exposed to very cold temps which probably added to the degree that which the tar is stuck on.
BMW CCA #: 399644
Old 03-12-2010, 12:51 PM
Fast Bob's Avatar
Keeping it surreal
Try the Ronsonal....
(R.I.P. Jever)
Old 03-12-2010, 01:43 PM
Mein Auto: B25
Old 03-12-2010, 01:52 PM
@ ^^ rocks have already chipped the hell out of the v710 weak ass paint job. no way in hell im going to take that murder knife to them
BMW CCA #: 399644
Old 03-12-2010, 02:08 PM
Mein Auto: B25
Old 03-12-2010, 02:11 PM
dboy11 dboy11 is online now
Mein Auto: 99...540i
Goo Gone, WD40 or mineral spirits will take the tar of as long as you let it dwell on the surface for a while
Its Going To Cost How Much???????
Old 03-12-2010, 02:34 PM
jvr826's Avatar
jvr826 jvr826 is online now
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
+1
You need to let it soak in. I use 3M Adhesive Remover to get the gunk from wheel weights off. I saturate a rag, then saturate the gunk and let it sit for a few minutes, then it rubs off with very little effort.
Have you tried Stoners Tarminator? Same deal tho, has to soak for a few minutes for it to work.
Jeff R.
Old 03-12-2010, 03:12 PM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by jvr826 View Post
Have you tried Stoners Tarminator? .
I think I used this to clean a bong once....
(R.I.P. Jever)
Old 03-12-2010, 07:58 PM
hahahaha at the comment and hahahah at the thought of bob stoned
BMW CCA #: 399644
Old 03-14-2010, 02:55 PM
catso's Avatar
catso catso is offline
catso
If it's actually tar, warming it up will make it much easier to clean off regardless of the solvent you choose. Leave the wheels in the sun or warm up the tar with a heat gun or hair dryer. But remember many of these solvents are flammable.
