Old 03-14-2010, 07:34 PM
the grants the grants is offline
Mein Auto: 03 325i
no power steering!
bought 03 325i 30000 miles somewhat wrecked {passenger front wheel suspension gone} replaced steering rack , and power steering pump ,aftermarket, still no power steering , is there a check valve i am missing ? or crappy pump,castrol fluids and raised wheels left to right but nothing? thanks brad
Old 03-14-2010, 10:30 PM
catso's Avatar
catso catso is offline
catso
Did you replace the reservoir? Maybe the filter in it's clogged? If I recall the hollow bolt from the pressure hose to the rack is a kind of one-way check valve. I don't know if the other one is the same. Maybe you reversed the two when you did the rack. Did you bleed the system correctly?
